Where can I find....
I am looking for 18" five spoke BLACK rims.
Light but wont break the bank.
I read the F56 has a 5 x 112 bolt pattern. Is this correct?
If I went 18 x 8, what would you recommend as the correct offset? I see 45, 40 and 35's.
and then, finally, what size/make/model tire to get the "perfect" look based on all this.
thank you in advance.
btw - I found this rim, which I like, but they do not post weight, only a price of $180 each which is not too bad....
http://www.nm-eng.com/338/0/0/3086/n...ght-wheel.html
They're no the cheapest, but the bore is matched, you can use the MINI center caps and lugs.
Azzurri
06-10-2003 01:34 PM
