FS:: N14 PCV delete
N14 PCV delete
Price: $16
Location (Region): West
Item Condition: Brand New
Here is a link further explaining and showing what this does and how easy it is to install. http://www.etuners.gr/en/index.php?s=12&t=299
the catch can would be a nice added part to prevent oil getting in the turbo but it is not required. when in boost the blow by is already pushed thru the full load breather into the turbo since the check valve in the valve cover closes to prevent boost leak in to the valve cover. those block offs stop pulling oil in when under vacuum at which time there is low crank case pressure. But if your that concerned I have one bsh r56 oil catch can for sale for $145.
