FS:: JCW Calipers
JCW Calipers
Category: Brakes
Price: $900
Location (Region): Midwestern
Included with the calipers:
brake lines
pad sensors
pads
all hardware except the caliper carrier bolts
The only item you would need for install would be rotors. You can source Centric brand rotors for the JCW for about $29 each.
I will only sell these as a set.
SOLD
The base Clubman (FWD and All4) and Clubman S (FWD and All4) use the same rear calipers and rotors. The rotors are 280X10mm.The JCW Clubman has larger calibers and rotors front and rear vs non-JCW clubman's. The F54 JCW has 300x20mm rotors. These would be a direct bolt-on to any F54 or F60 given you upgrade to the JCW rotors. IF you were to retrofit the 300mm rear brakes to a F55, F56, or F57 then you need to modify the EMF actuator for the rear calipers.
CHiCO43 (08-23-2019)
antirich
05-04-2021 07:57 PM
R99
02-16-2015 02:50 PM
