FS:: Alta Rally Lightbar with Hella Fog Lamps
Category: Exterior
Price: $125
Installation is pretty simple. Remove the bumper cover and aluminum bumper. Drill four 7/17 inch holes through the bumper. Test fit to see where you need to punch through the lower grille. Install the switch and wire. Then reinstall the bumper and cover. Wire-up and adjust the fog lights. With the car on level ground about 25 feet from a wall. Find the centerline and cutoff line for your low beams and mark the center about 4 inches below. This is the aim point for the center of the fog lights. Tighten up and check the pattern.
Interior/Exterior install fog lights in front bumper
trashmanbob
03-22-2012 03:04 PM
