Speedo Error
on
Speedo Error
I checked my speedometer against a GPS unit. I believe the GPS unit to be accurate. The speedo reads 60 and the GPS reads 59. At 75, the GPS reads 73.
Is there an easy way to have this corrected? If I bring a table of speedo speed vs actual speed can the dealer change this? I have an 07 MCS with stock wheels and tires of the sport package variety.
Paul
Paul
Let's try that again, you moved this thread on me!
Ultimately, the CW may be that it is purposely programmed, but there is a question to GPS accuracy too...
https://www.northamericanmotoring.com/for...t=speedo+error
There are multiple other posts/threads on this subject. I'm on my 2nd MINI (first was a 2005 Cooper, new one is a 2007 MCS) and both speedos are high about 3%. This means speedo reads 60 when your actual speed is 58. Your GPS is extremely accurate when monitoring speed as long as you're not accellerating/decellerating and you have relatively good satellite reception.
The other posts seem to indicate this is a common problem, not only with MINI's but with some other manufacturers as well. I discussed this with my dealer and they know the speedos are inaccurate and say it is a design issue. The problem I have with this is that the odometer is registering more miles on the car than you've actually driven, which could affect the warranty service.
I doubt it. If they were going to adjust yours, they would probably make read 5% optimistic instead of the less than 2% you repored in the first post. I believe the law says a car's speedo can read as much as +10%, but cannot read < than actual speed. So, mfgs. typically make speedos about 5% optimistic. Consider yourself lucky that yours is so close to perfect.
I noticed my 04 MCS was reading 33 when I went through one of those radar trailer things and it was reading 30. (You know the little radar guns they mount on a trailer to tell you how fast you are going)
I can only remember a couple cars I've ever had that were dead on, most have been over by a little.
Answer from Manufacturer
Attached is explanation from Produce Engineering in Woodcliff Lake, NJ.
Sounds like BS to me that one would have to do the math. Why can't one of the best automobile manufacturers in the world solve this problem?
Mini Speedometer.pdf
R50/53 Help please.. Odd issue.
PsychoRallye
21
02-17-2019 06:08 AM
BucksCountyR57
R57 :: Cabrio Talk (2009+)
11
09-30-2015 02:11 PM
dutchhome
09-30-2015 07:17 AM
