Manually raise window
My window is stuck in the down position and I would like to get it closed. It has to be the motor stuck as I can hear a relay click when I move the switch. I've tried the old "hit the door" method but it is stuck.
Is there something I could disconnect to release the tension of the motor so the window will slide?
before takinf off the door panel give it a couple of good taps on top of the speaker, thats where the motor is. hopefully this will free it and you can use the window for the moment.
if that doesn't work then take off the door panel and give it some more taps with a rubber malett.
good luck!
good luck!
Mine has had issues with power window motors on both sides on seperate occations. Needed new motor each time, replaced under warranty.
On a side note, is it possible to convert the windows to crank windows? What about a crank-electric hybrid wherein you can use the crank if you want or the switch? Would be cool I think.
I fiddled with it but seeing as the way to replace the motor included starting with it in the up position. It was beyond me. I was finally able to get it to the dealer, got a loaner, and got it back several days later. The motor and regulator went out. The regulator was why the beat on the door method didn't work I assume.
UncDeo
11-04-2019 04:08 AM
wildwestrider
12-27-2015 08:20 PM
