Anti-Stop Brakes
Old 07-17-2007 | 07:02 PM
ScottinBend's Avatar
ScottinBend
Originally Posted by tigertiger
The chrysler was a '91. It had air brakes (high pressure), I was warned that they were dangerous to work on. Training? Nobody said boo about it.
The dealer "checked it out" twice after my complaints, they told there were no problems. I was never to "Slam on the brakes!" .
Air brakes..........
This unfortunately has the affect of giving your arguements absolutely no validity.
  #102
Old 07-18-2007 | 12:34 AM
Dr Obnxs's Avatar
Dr Obnxs
PErfect example of "wedge" effect....
run-away truck stopping zones. Lots and lots and lots of deep gravel. Then a huge berm of gravel if that wasn't enough! Wedge that, sucka!
Matt
  #103
Old 07-18-2007 | 01:05 AM
ScottRiqui's Avatar
ScottRiqui
Originally Posted by mauberley
Hmm. Can I bicker with your fast and loose use of force? In general, the picture you're trying to convey has some truth, but the analogy or use of terms is just...bad.
True. You can't say that the sum of the frictional forces available for acceleration and turning always add up to 1 (or any other constant), because that ignores things like weight transfer.
I usually just talk about the "friction circle":
It shows graphically that the more you're accelerating or braking, the less you'll be able to turn. (The only allowable combinations of lateral and longitudinal acceleration are the points on the heavy line or inside the circle). That's a generic picture, since the friction circle varies from car to car and also depends on the road surface, but the general shape is always the same.
The curve of the lines shows that there's not a one-for-one tradeoff between lateral and longitudinal acceleration, though, or else it would be a "friction diamond" and not a "friction circle".
  #104
Old 07-18-2007 | 03:10 AM
msjulie33's Avatar
msjulie33
You aren't supposed to pump ABS brakes, some know this but many (most?). don't seem to know that you never pump non-ABS breaks either; use threshold braking if you have non-ABS brakes. Pumping any kind of brake just causes harsh dynamic changes to the car's balance.
Yikes.. caught back up in this thread!
  #105
Old 07-18-2007 | 03:45 AM
daflake's Avatar
daflake
LOL, sucker!
Tires, Wheels & Brakes
09-10-2015 01:27 PM
09-10-2015 11:52 AM
Tinklespout
16
09-06-2015 12:39 PM
09-04-2015 10:23 AM
PelicanParts.com
09-03-2015 04:22 PM
