Wind Noise at anything over 75mph!
Anyone else have this problem? There is a wind noise that is very bad anything over 75mph and stays consistant all the way into triple digits. I thought it was the wipers so, adjusted them lower on the windshield. This did nothing to help. Also, adjusted the vents from the feet to the windshield and the noise does not change. Anyone else having this problem? Any fix for this? Going in next week for a problem with the passenger airbag sensors. So, will take it up with the dealer.
Yeah, I asked the same question (here). Got some answers. Worth your time to read about how people are playing with tape to mitigate the "howling" as I call it.
I've found that, with my autobahn driving, the noise can start as low as 70 or 80 mph, but pretty much it's guaranteed when zipping along between 100 and 110.
The odd thing I found was that when I pushed it up to about 130+, 140ish, it was as if I had broken the sound barrier -- the howling stopped. Not that in AZ you'd like get the chance to hit 140, even on a good track day. It just says something about the design issue involved.
Get some masking tape and play.
My 06S did this but only when above 95. And it could be regulated and eliminated by readjusting the vents from out the front to the windshield or floor. On my 07 nothing seems to modulate it. My wife calls it my slow down signal. I understand that these cars are not sound proof but, this high pitched wind whistle at only 75 is a real pain. Most the roads out west have 75 speed limits.
your's could simply need adjusting. The is a bulletin on it that the dealers have. They can fix it.
Great news. The dealer was able to re-create the wind noise at about 60 with a cross wind on the interstate. Their comment was, "wow what an excessive and loud noise, you were not kidding". I told them it sounded like a freight train coming through the cab. They found a leak on the upper part of the windshield. They called in a windshield company and were able to reseal the window without removing it.
Now if they can figure out the airbag sensor in the passenger seat. It keeps coming on when my wife is setting in the seat.
I've got the same noise.. although it sounds like it's coming from the upper passenger side front of the sunroof. I do know there are Puma cases for early builds that need sunroof adjustments. Mine is going in Tues eve for the wind roar and my 3rd to 2nd gear issue (again for the 3rd time).
There are 3 torx screws on each side of the sunroof. The screws are horizontal, at the glass edge, interior sides. Loosen the 3 screws, and push the glass forward, pushing on the black plastic bar at the front of the sunroof. Tighten the screws, and road test.
Mine was making a lot of noise on the right side. Did the adjustment, and it is almost totally silent now.
The problem happens when my wife sits on the passenger seat as well. Its not really a problem, more like a seat adjustment. You need to raise the seat up till her the back of her thighs are firmly pressing against the end of the seat. My wife is 104lbs and it goes off constantly.
I've got the same problem with no sunroof, minipete07. One of the possible answers was above re a leak in the windshield sealing. But I live in Florida and have been thru some pretty heavy downpours and there is no liquid leak. So I'm thinking, if no liquid is leaking no air should be leaking and making noise.
I've got the same high pitched whistle at freeway speeds. I'm sure its not the sunroof as I have just slightly opened it when driving along and the whistle doesn't change. I've also had the front windscreen replaced, and still the noise persists. I'd love to know if anyone manges to track it down.
I had the bonnet up yesterday and accidentally hit the heat shield on the turbocharger. It made a bit of a rattle and when I slapped it a little harder it made more of a rattle. Methinks this could be the unidentified buzz at highway speeds.
I had the same wind noise. It started at about ## MPH. I told the dealer about it and they said they could not have the mechanic drive it over the speed limit to check. I checked the 07 MCS (JCW) they gave me that day and no noise (took it to ### MPH). I went over every inch of my car that weekend and checked every piece of trim, molding, etc... On the next drive no noise, YIPEE!!!!
Here's a video of the windshield seal noise. If you have a bad seal, you do not have to be going triple digits, just fast with a cross wind.
http://vids.myspace.com/index.cfm?fu...deoid=18388730
#5 LEGAL - Posts relating to street racing, excessive speeding, or violations of other laws are prohibited. If you want to race, take it to a legal venue.
