for those who've changed out their slave cylinders
I am doing a transmission Swap and noticed my clutch slave cylinder was leaking from the boot. So I ordered a new one. I installed the new one and fluid comes gushing out from the hose connection. I have taken off the connection a bunch of times now and tried reinstalling it to somehow magically make it seal. I've looked over the new cylinder and there are no cracks or abnormalaties. What is it that I'm missing? I'm sure it's something painfully obvious
yes you are missing the really small o ring. its probably stuck in the inside of the old cylinder still. it goes over the metal tip you insert in the slave.
good luck finding it!
do you have a pressure bleeder? it will make your life easier once it comes time to bleed the system, is a pita.
