Does your car weep?
Old 09-06-2007, 11:30 AM
crump500's Avatar
crump500
crump500 is offline
No more weeping, Zoey got a new washer jet and a check valve at the dealer. It appears to be the correct fix.
  #102
Old 09-06-2007, 07:55 PM
Candyman's Avatar
Candyman
Candyman is offline
I thought the check valve was the problem-- I think it keeps fluid at the jets which then has nowhere to go when the fluid expands. I took mine out and put a standard vacuum tee in place of it, hasn't wept yet and there's no noticeable delay when I activate the washers. FYI both lines leading to the washers were full when I pulled the check valve.
  #103
Old 09-07-2007, 05:22 AM
aem421's Avatar
aem421
aem421 is offline
^^That would explain a lot. Mine is a week 31 production model and it hasn't wept at all. Maybe MINI figured that out by the time mine was made. I seem to have a lot of different stuff than the earlier models.
  #104
Old 09-08-2007, 02:26 PM
jw34's Avatar
jw34
jw34 is offline
My MA said last night that the mixture in the washer fluid reservoir from the factory contained some sort of alcohol mixture which is what is staining cars when the washer weep. Has anyone else heard this? He told me I might want to empty the reservoir and put in regular washer fluid when I had a chance.
  #105
Old 09-10-2007, 07:55 AM
Rastven's Avatar
Rastven
Rastven is offline
I've got a weeper so I'm going to drain the tank and try with regular fluid. If that doesn't work I'll see what the fix is when I head back to the dealer to get my plates etc.
I don't notice any real staining (I think the fluid effected the wax not the clear coat) but I'm keeping an eye on it and will wash the hood regularly.
  #106
Old 10-04-2007, 05:28 PM
PHX ATC's Avatar
PHX ATC
PHX ATC is offline
3 days old and it weeps.
  #107
Old 10-04-2007, 05:30 PM
VeryRedMCS's Avatar
VeryRedMCS
VeryRedMCS is offline
I noticed that my new MCS had slobbered all over the hood right after getting it home from the dealer. :impatient
  #108
Old 10-04-2007, 06:33 PM
porkchop's Avatar
porkchop
porkchop is offline
  #109
Old 10-07-2007, 04:54 PM
Jinxy's Avatar
Jinxy
Jinxy is offline
Mister-TV-Lamp -- If you just took delivery, you should take it back to the dealer, hand them the key, and tell them to give you a call when they have fixed the cause of the problem.
I'll apologize now for the following rant, but it has become my pet project .
If you have an '07 MCS manual transmission, it is quite likely that the engine and turbo are super heating the underside your bonnet. Touch the center bonnet area just above the scoop after you have run the car and parked it. Touch it right after you turn it off, then in 5 minutes, then in 10minutes. You won't be able to keep your hand on that spot.
My bonnet gets as hot as 235F (using an IR temp gun). With a temp probe stuck inside the scoop, yesterday I got an all time high temp of 278F .
The water in your washer reservoir boils at 212F. Mini has been aware of this problem since at least March and have yet to address it.
It is my opinion that all '07 MCSm owners that have the weeping jets and scorching hot bonnet issue should log a complaint with NHTSA, as this is a safety issue. Anyone touching that area of your bonnet could suffer a burn injury.
The ECU controls the cooling fan and turbo water pump. Mini could resolve multiple issues by making a simple ECU adjustment. Not enough owners have made enough noise. It's time to start making some noise. It appears the only way we might be able to get Mini's attention is by complaining to NHTSA.
8 months and Mini Inc hasn't stepped up and resolved this issue...Why??
Good luck. You're gonna love this car (really, it's a blast to drive).
  #110
Old 10-08-2007, 02:13 PM
Candyman's Avatar
Candyman
Candyman is offline
I took the check valve out (which keeps fluid at the jets by stopping it from draining back into the tank) and replaced it with a vacuum tee.
This gives the fluid a place to go when it gets hot, and it does not weep on the hood anymore as a result. Truly a 30cent fix for those who don't want to go back to the dealership.
  #111
Old 10-15-2007, 11:15 AM
Kasey's Avatar
Kasey
Kasey is offline
I'm not very mechanically inclined, any chance of a picture of the vacuum tee and where you put it?
  #112
Old 10-15-2007, 11:23 AM
pastabatman's Avatar
pastabatman
pastabatman is offline
I'm a little confused. Are you saying you got the 'checkvalve' fix from the dealership and it did not fix the problem, so you swapped it out for a 'vacuum tee'? I also would like to see some pics.
I picked my my MCSa last week, and just noticed some tell-tale dried streaks on the hood. I'm also seeing some dribbling from the rear washer after opening & closing the back door.
Thanks,
Pasta
  #113
Old 10-15-2007, 02:39 PM
valthun's Avatar
valthun
valthun is offline
I noticed this occurred once on a spirited drive through malibu canyon, The AC was fluctuating as well. that is the only time it happened. I drive an MCm not an MCSm. So maybe this is something for all R56 in regards to the weeping and hot engines, although obviously mine can't get as hot as the S. I also noticed the weekend previous that I had a strange odor of something burning in the engine compartment. After inspection it smelt like burning paper.
  #114
Old 10-25-2007, 05:03 PM
valthun's Avatar
valthun
valthun is offline
I just noticed this occurred again this week, so I have contacted my SA through their web service. I have received an email and they want me to drop it off by Monday. I am determining what the status of the service will be and if I can get a loaner if it will take more than one day. Since my roommate is also a co-worker I can live without the car for a day, but dropping off and picking up can be a pain.
  #115
Old 10-26-2007, 07:12 AM
Duffer's Avatar
Duffer
Duffer is offline
My week 37 build weeps and has stained my black stripes.
  #116
Old 10-31-2007, 06:24 PM
Bhatch's Avatar
Bhatch
Bhatch is offline
My week 39 MCS leeks.
I noticed it today, it got the car last week.
  #117
Old 11-01-2007, 06:16 AM
minibayb's Avatar
minibayb
minibayb is offline
Got mine 2 weeks ago this coming Saturday. Noticed that it was leaking when I got it home. It has also stained the bonnet stripes but did not stain the paint. How do you get the bonnet stripe staining off?
  #118
Old 11-01-2007, 07:44 AM
Duffer's Avatar
Duffer
Duffer is offline
You don't, my dealership is going to replace them.
  #119
Old 11-01-2007, 06:10 PM
minibayb's Avatar
minibayb
minibayb is offline
Well, that may be ok if I was closer to the dealer but the closest one is 4 hours away. Actually there is not one in the state (WV). So any solutions without dealer intervention.
  #120
Old 11-01-2007, 07:34 PM
spfdhed's Avatar
spfdhed
spfdhed is offline
My week 34 weeps from the left, but not the right. What is the vacuum tee fix? Where did you put the "tee" (at the "tee" connection btw left and right washer hoses or what)?
  #121
Old 11-02-2007, 11:43 AM
Duffer's Avatar
Duffer
Duffer is offline
So any solutions without dealer intervention?
Check this thread I started in the detailing forum.
https://www.northamericanmotoring.co...d.php?t=117548
  #122
Old 11-03-2007, 03:26 PM
valthun's Avatar
valthun
valthun is offline
I just got back from my dealer, the MA had never heard of the issue. However service looked at it, and they are ordering parts. They are going to call when the parts arrived.
  #123
Old 11-10-2007, 07:33 AM
minibayb's Avatar
minibayb
minibayb is offline
Well finally had the opportunity to try to get the bonnet stripe stains off today. Bought claybar and other supplies last night and felt at least armed and ready to do battle. Washed the car then started applying claybar to the stripes. (I bought the Ice liquid claybar) Could tell after the 1st application that it was improving and removing the stains. After several applications the passenger side stain was all but gone but the drivers side had one streak still visible. After several more applications the drivers side still visible but still improving. After another application I noticed that the stripe around the streak (which was still visible) was "browning" which indicated that I was rubbing through the black portion so that is where I quit. Streak still visible but with the added bonus of stripe discoloration from my vigorous efforts . I guess I call the dealer and see if they will replace the stripes. I hope they will send them to me and I can have them installed here as I am about 7 hours from the dealer.
  #124
Old 11-10-2007, 09:17 AM
Konquest's Avatar
Konquest
Konquest is offline
stripes are covered by the warranty, the dealer will replace them for free if you take it in for service
  #125
Old 11-10-2007, 12:40 PM
valthun's Avatar
valthun
valthun is offline
My car is going back in on the 27th for the new parts. They are providing me with a loaner. I will probably have to wait until summer to determine if it did any good though. Since I need the extra outside heat. But since those with the MCS are noting it is fixed, i am hopeful.
Quick Reply: Does your car weep?
