C.V. Boot Replacement
99% of the time you buy a rebuilt half shaft. With road grime and the need of a press to get the joint off your money ahead to go with the rebuild. Now for the 1% they do make a boot that will strech over the joint with a special tool and will still have to take it apart to the point of 2 min later the old axle is in your hands and you don't have to clean and prep the joint and just slip in the new one. http://www.bailcast.com/duraboot
Thanks!
I should have mentioned that I work in the Parts Dept. of a Nissan Dealer, so I have access to lifts, air, and a couple of eager and willing youg techs with tool chests big enough to have their own zip code!
I have an OEM boot kit on order from my friend at the "MINI Store". I was just trying to find out if there were any special issues with removing the shaft from the car.
Jim
Jim
speedbird_1
08-15-2015 04:44 PM
