Notchy shifting?
Notchy shifting?
I drive a 2003 MCS.
Do most Mini's have a 'notchy' shift into the gears? My Mini does and it has always been like that. I have never really thought anything of it until I let a friend drive the other day and he seemed to have a harder time getting it in to gear and it made me notice that it definately 'snaps' into gear. It is not that difficult to put it in gear it just requires more input than a light push of the hand.
Oh, and reverse really requires heavy hand pressure to push it over and up into reverse. Is this anything to be concerened about or is it normal?
Thanks,
k
Thanks,
k
-1
Mine does the same thing. Its sorta feels like there is a detent that you have to push past to get it in gear. I find it a little offsetting because I feel like its gonna break. But, I live with it.
-1
I like the shifting feel on it and the reverse is understandable because you wouldnt want to accidentally throw it in reverse. I was teaching a friend the other day in my mini how to drive a manual and she couldnt even get it into reverse because it was so hard for her to push it over haha.
I've driven cars that have all types of shifter feel. My Lotus Europa has the stiffest gear lever in the world and is not gated but it somehow works and I can easily shift it smooth as silk. I've driven Honda's that just slide in and out of gear and that seems to work fine with them. Same for Toyota's. I'm not a big fan of the MINIs shifter. A little notchyness is fine but it's too much for my liking. Many have said a Whalen **** helps but I feel that the added weight up top makes things a bit sloppy. I'll probably try a SSK to see if it helps with the slop (which is going to make it even more notchy). I'm still searching for the best compromise for my MINI.
I like it except...
... I'd like reverse to require some additional positive action, like, for example, pressing down on the lever (an old VW design),
The only other thing I don't like is that when shifting down into 2nd from third, it is a little too easy to miss the down stroke for 2nd, andgo right by it so that you are still in neutral. I REALLY DON'T LIKE THAT. I'd like it to be not possible to go "past" 2nd (too far to the left).
I don't know if "notchy" is the word I'd use to describe it, but it is not as precise as what I am used to. Meaning there is more play in the shifter than I would like, but the actual shifting into the gears is smooth and easy. Of course, reverse does have a detent to overcome. But that is for obvious reason. I was/am, considering a short shift, but am concerned about some of the fitment issues I have read about, as well as the installation hassle.
Last edited by Loony2N; 08-31-2007 at 08:37 AM. Reason: typothetical error correction
Yes, the 2nd gen shifter is much smoother (sloppier) than the more precise (notchy) feeling of the 1st gen shifter. Actually, the feel of the gen 1a shifter ('02-'04) is about half way between the gen 1b ('05-'06) and the gen 2.
R50/53 Help please.. Odd issue.
PsychoRallye
21
02-17-2019 07:08 AM
MINI Stupor
10-01-2015 12:36 PM
