R56 Armrest - dealer installed
I ordered my MINI and then decided I wanted the armrest, so it was too late to change the order and have it factory installed. The dealer installed it recently but it doesn't raise high enough to really be out of the way for shifting. Has anyone with a factory-installed armrest encountered this problem?
Also, does the factory-installed armrest consist of the rest mounted on a black painted metal frame that attaches to the seat bolts? The dealer-installed armrest is and it seems kinda' cheesy to me.
There are several other post re; this if you do a search.
I bought my R56 off the showroom floor and asked if they could put an arm rest in it. I assumed it would be like the factory installed one. When I picked it up it has the one you got. I tried if for a few days and hated it. I made them take it out and refund the money. It wouldn't stay up, wouldn't go up far enought be out of the way; the vinyl on the top irritated my arm; it was in the way of the parking brake......
No one seems to be crazy about the factory one either. FYI
If it keeps sliding open...
It isn't properly closed. You need to push slightly down as you slide it closed. I noticed this right after it was opened the first time (it was very tight). If you look when you go to close the slide cover you will see a slide gromet at the back of the panel, if you don't apply pressure it doesn't engage. Problem solved.
15-cd jewel case from Target. Functional. Nice anthracite/silver color. Fits between the 2 seat belt latches perfectly atop the e-brake boot, and you can move out back of your way if needed. Have had the same one in my 05 and 09. $8.99 last I looked.
MINI armrest = most worthless and dopey option EVER! How do they expect us to perform effective handbrake turns with that thing in the way??
sequence's jewel case is no-doubt, 'most-for-the-money' and best for handbrake spins.
I love my Euro Armrest version:
This is the "Black Steel Frame" (sturdy mount) mentioned by OP.
I have added 'Memory Foam' padding and shimed to higher angle.
Best and Lowest cost supplier is Minspeed eBay had one for $10 less, but that ended.
07-16-2020 12:54 PM
minicoclub
11-11-2015 07:25 AM
squawSkiBum
10-02-2015 09:21 AM
