Bonnet Heat/Deformed Scoop
#51
FugitiveAI - The burning hot bonnet issue appears to limited to be limited to just manual transmission models.
Is yours a manual (MCSm) or auto (MCSa)??
Let's see a pic of those new wheels on your Mini
EDIT: Opps wrong thread, there's a duplicate running in Cooper Talk (2007+ )
New EDIT: I had the duplicate thread moved to Stock Problems/Issues , since I started that one.
#52
#53
#54
korby -- I'm going to start logging my temps and posting them here once a day. Care to join the campain? Plus you'll get to use your new toy every day. It will be something like:
Morning Commute
Start bonnet temp: ----- 75F
Dest. bonnet temp: ----- 140F
Dest. b-temp +5 minutes: 205F
Evening Commute
Start bonnet temp: ----- 87F
Dest. bonnet temp: ----- 150F
Dest. b-temp +5 minutes: 210F
Let me know what you think.
Morning Commute
Evening Commute
#56
#57
#58
#60
pic of "functinal hood scoop"
Picked my manual MCS up thurday night and have been driving the crud out of it(250 miles) I was aware of this issue and asked my MA if the hood scoop was functional and he said no. When I looked at it every other row was open. I have been feeling the area around the scoop after each drive(keeping under 4500 rpms) it is warm, bot not hot to the touch. I am going to try to get a temp gauge as I like gadgets. I went to my friends house tonight to show him my car and he has a 2004 MCS. The scoop is wider with no slats at all. He had a few bugs on his intercooler but no big deal. So what is the point of the grill?
Wolfgang
Wolfgang
#62
Picked my manual MCS up thurday night and have been driving the crude out of it(250 miles) I was aware of this issue and asked my MA if the hood scoop was functional and he said no. When I looked at it every other row was open. I have been feeling the area around the scoop after each drive(keeping under 4500 rpms) it is warm, bot not hot to the touch. I am going to try to get a temp gauge as I like gadgets. I went to my friends house tonight to show him my car and he has a 2004 MCS. The scoop is wider with no slats at all. He had a few bugs on his intercooler but no big deal. So what is the point of the grill?
Wolfgang
Wolfgang
#63
holey
They replaced my scoop, one with the holes in it even, at 3500 miles because it was melted and deformed. When the new one came in I made sure the tech checked for the ventilation holes in it, and since the replacement didn't have any he put the grill out of my old one in the new scoop. The new one is chrome (I had to pay @$20 to get them to "upgrade") and seems to be holding up much better.
#65
Alton's the man. He even rides a BMW motorcycle. That's almost sort of like a MINI. I'm sure he could rig up some sort of grill barbeque apparatus to change the MINI from a unitasker into a multitasker.
#66
#67
If yours isn't getting that hot, then maybe Mini has updated the ECU to make the fan and/or turbo water pump run a bit longer. When was yours manufactured?
#68
Took some temps today
Mine was manufactured 08/07 just got it.
I bought an infared temp today.
After a 20 minute spirited run I took temps every five minutes. (90 degrees F in Dallas today) The hottest temps where at fifteen minutes after stopping. One note the cooling pump thingee stayed on for only 30 seconds after turning the car off.
Temps:
158 F- at the hood directly above the sccop
170 F- at the junction of the hood and the scoop
152 F- on the top part of the scoop above the opening
165 F- pointing the temp gauge into the scoop, but at the middle portion which is blocked off.
203 F- pointing the temp gauge into the scoop into one of the openings.
135 F- at the bottom of the scoop
I could feel the very hot air venting from the scoop, kind of like a convection oven.
I am going to take some more temps to make sure everything was correct.
I read on a post that the dealer has a chrome scoop grill that is fully vented. I think I might get this soon.
Wolfgang
Temps:
Wolfgang
#70
on
I wonder if un-corking the fake hood scoop would help lower engine compartment temps. I've seen somewhere on here where people have made or are making the hood scoop functional in hopes of increasing HP, but it may be a better benifit in just keeping overall engine bay temps down. Anyone on here have there hood scoop functional and try measuring temps?
#71
#72
Its not that hot
I will have to check the build of my car but it has to be sometime march april . I bought mine off the dealor lot. (07 MCSm) . I drove yesterday around 40-50 miles and checked the hood. It was pretty cold. Infact, I was really expect it to warm up .
May be I am doing something wrong.
On a side note , the rubber door sealer at the top of the rear windshield on outside has come off a little in the center. Took it to the service, and they said they will have to replace it. Not a biggie but my $13k honda civic never went to the dealer apart from regular service while my mini has already been there 3 times in 2 months - albeit for trivial problems
#73
This engine would be ideal for cooking on. If you think I'm kidding, I'm not--there is a whole book (can't remember the title) on cooking on car and truck engines, with food wrapped in foil. I actually tried this on vacation a couple of years ago, but it didn't work well due to the configuration and lack of heat in our rental van. Bet it would be different in the MINI, though.
Unfortunately it seems to be out of print.
#75
That is NOT a "Bonnet Scoop"!!
It is the MINI BBQ Grill attachment. It was supposed to be an add on option for $250, but instead was added to all the Cooper S models. Simply run your car for a few minutes, then place your frozen or thawed burger pattie onto the MINI Grill. Let stand 2 to 4 minutes (2 minutes = medium rare, 4 minutes = well done). You will be plesantly suprised by the tendor flavor locked in by the quick searing action of the MINI BBQ Grill. Best of all, your MINI burger will be healthier than normal due to the slanting of the grill forward. This allows all the colesterol soaked grease to drip forward and away from your miniburger!!
Don't forget to bring along condiments and buns, and store your meat in the refrigerated glove box on your way to the picnic!!
Enjoy!!
Enjoy!!
