2007 MCS Xenon Headlights
I have a HUGE issue with my xenon headlights. This is my 2nd MCS so its not as though I am not used to the brightness. The problem is the lights are bright and shine in everyones eyes. Oncoming traffic constantly flash their brights at me. This would include police officers, buses, SUV's, etc. People I am driving behind are flipping me off and adjusting their rear view mirror. I am to the point where I don't even want to drive at night. I have taken the car to the dealership to see if the lights can be adjusted but they say the lights are perfect. What can I do?!?!?!
If you are parked on a level surface and turn on thelights how bright are they? How far do they extend out? Xenons when in low normal position have a sharply defined cutoff about 100 feet or so in front of the vehicle. In high bright mode it is like a big search light. Are you sure that your brights are not on all the time?
One thing I would do is try to find someone else in your area, or even go to the dealership and see another 07MCS with Xenons. Compare it to your car. See if they are different. If it's at the dealer, maybe they will even let you drive it in the dark to compare.
If the dealer is trying to tell you this is the way they all are, then make them prove it by comparing against another vehicle.
Here's a quick way to check headlight (and driving light) alignment...
Find a level parking lot with a wall (I use a local school). Drive right up to the wall and turn on your headlights. Note where they hit the wall. As you back the car away, watch where the lights contact the wall. If the contact area goes slightly down the further you are from the wall, you should be fine. If it doesn't, or if it goes up, you need to see the dealer (assuming you're under warranty) or adjust them yourself. Good luck!
There is a hole to the inside of the headlights that lets you use a screwdriver to adjust the headlights manually. Just a half turn and it moves it a LOT so be careful (remember that a cm or so on a wall gets inflated under bigger distances on the road)...it took me about an hour one night driving around and testing before I felt I got it just right.
What I did was park up close to my garage door and watch as it slowly rose or sank (use tape to mark off where you currently are)....This also made it easy to match up the other side to the same cut afterward.
Also, the cutoff on xenons are made so that the passenger side is inevitably higher. That 'crease/bump' in the middle puts the passenger side a few inches higher to see farther down the road.
07-16-2020 12:54 PM
12-23-2015 10:36 AM
Powershift
08-16-2015 05:14 PM
