Flooded battery box
Flooded battery box
I went to put a new tire plug kit I got where the battery is. Then to my surprise I discorvered this
WTF My car is usually garaged and rarely see the rain. But I was in Maryland this weekend and it was raining the entire way down on Friday and the car was parked outside Friday night in the rain.
Anybody else have this problem? I was worried about something shorting out so first I took a pic so I can show the dealer then moped it up with a towel. Wished I had a shop vac. I'm sure if I popped out the battery vent tube grommet the water would easily drain out but I didn't want to fuss around with the shield under the exhaust.
After I cleaned up, I checked everywhere in the boot area for any signs of moisture. I checked inside the tail lights and it looks bone dry. Checked the foam under the hatch opening and again, bone dry.
I noticed some yellow residue inside the box though. I'm hoping it's just the cosmoline.
So for now I just propped up the boot floor with the tool kit and left the hatch open so it can completely dry out. Hopefully my dealer can find out what's wrong.
On mine the brake light leaked. I don't think this problem is unusual. For me I noticed it when the boot mat was wet. I took the rear hatch apart and it was bone dry. The tail lights were also perfect.
I suggest starting with the tail light gasket.
Rich
Rich
You could always hop in the back with a flashlight and have a buddy hose the car down with a hose. That should reveal any obvious problems. Actually, that what the dealer will do. They'll have the runner drive and the tech ride in the back, then they'll run it through the car was a couple times. At least thats what we used to do back many moons ago!
Yup,
It's a real shocker. I found the same thing this summer. I had seen water showing up on the upper inside rear RH side glass and had assumed that there was a leak some where in the roof seam. I pulled the headliner away from that area and found that the drain tube which connects the sun roof drain to the port above the rear hatch had become disconnected. It's just a small rubber tube pushed onto a metal nipple. The leak showed up on the glass, but ALSO filled the battery box. Looked like a sick fish tank. I'd bet you that's your problem.
Cheers,
Dave C.
Cheers,
Dave C.
I made a appointment with my dealer for later this week. It seems the box is dry so I put the boot floor back and closed the hatch. But I'm gonna ask my dealer to check under the battery for any signs of moisture or corrosion.
Oh, quick question. If you disconnect the battery, do you lose all your personal setting or just your clock and radio pre-sets?
I had the problem. It was the seal on the rear window. I was able to fix it with some caulk (mine is out of warranty and I am cheap). So far, it hasn't leaked again in about 3 months and I drive it all the time in the rain. Eventually though, I suspect I will have to replace that whole seal. The best way to pinpoint the leak is to sit inside while someone sprays a lot of water on the rear window. It will take a pretty fair amount to replicate the leak if it is anything like mine was. Hope this helps.
WTF it's wet again
I checked the box after driving around a couple of hours in the rain. There's only a trace amount of water inside the box. But the foam under the boot carpet was soaked on the passenger side . What the heck is going on? I noticed some sort of rubber or plastic plug on the boot floor. I'm wondering if watering is coming through there since the foam that's over it was soaked.
I checked the inside the tail light and it's bone dry. I also checked the headliner and again, bone dry. Urgh, don't tell me the leak is coming from the rear wiper again .
I have another oil change coming up next month. I'll have me dealer look at it again.
Try spraying water around the hatch glass and in the gap around the hatch and the body. The glass is bonded in place on the hatch, some people have complained about water leaking around the glass from a separated bond. The same is true for the rear side glass, which is also bonded. The tail lights and the 3rd brake light are also potential points of entry, as is the rear weatherstrip and the wiring tube between the hatch and the body.
on
I have also seen the clips that hold the rear chrome trim on leak, causing the same thing.
And If you remove the panel the covers the trunk latch, there are two vents under there to vent cabin pressure. It also leaks around the tops of those and water flows straight to the battery box.
Definitely get it fixed quicked befor you have to pay to install a new B+ Cable that runs entire length of your MINI. NOT CHEAP!!!!
My area got a good soaking on Saturday. My car was outside in the rain for a good two hours. So today I checked the boot area for moisture.
Bone dry . When I posted the last time, my car was exposed to the rain for about the same time and I found moisture. But this time it's bone dry.
Last time I checked, I noticed moisture around a oval shaped plastic plug on the boot floor underneth the carpet. Maybe water was making it's way past the plug so I put a piece of duct tape over the plug. So today I checked and the boot area is bone dry.
Anyways, I have a appointment for a oil change on Friday. I'll have my dealer do another leak test.
Did the dealer ever figure out what was leaking? I'm interested in hearing what they might have found...
I've noticed some wetness in my boot recently, which is a bit worrisome because the back glass AND the sunroof had been replaced at my nearest dealer prior to the warranty expiring in December.
So far I've only had a chance to check the 3rd brake light for leaks. It seems to be watertight...
Okay, I JUST picked up a Replacement 04' MCS today and my friend who picked it out just for me had it detailed and her guys discovered that the Battery Box was wet.
I HAVE LESS than a Month of Factory Warranty left and this MUST be fixed before then....
I've read thru and will try the 3rd Brake Light 1st... I hope it is taken care of fast!
MAy have to reset power windows too
