Lousy MPG on my 06 MCSa
Hey,
Recently i've noticed that I only get around 17 MPG on my 06 MCSa, the only engine mods done to it is a Remus Exhaust, I don't drive it hard I usually let it coast a lot, but I still manage to only get around 17 MPG the car has a bit over 4k miles on it, and I use Shell 91 Octane V-Power Gasoline. Any advice?
Thanks!
Thanks!
Um, why would this be?
Rolling diameter is the same and the weight won't necessarily be more so how/why would rim diameter reduce fuel economy?
I think you can safely scratch this as a possible cause...
A similar situation happened to me as well and I determined it to be improperly inflated tires. Since I've never owned run-flats in the past, I never bothered to check the air pressure as the tires seemed to be properly inflated. Low and behold, my tires were sitting at like 13 psi. Once I corrected that, my fuel economy went up to ~24 MPG in the city.
GotMINI
GotMINI
stop reading the mini trip info and do the math yourself! ithe trip computer is only a guide. not an exact reading. if you were getting 17 mpg, you would have raw fuel commg out of the tail pipes! besides, you only have 4k on it, let her brake in a little bit......... and check your tire pressures at least once a month
I have 06 MCSa. I am getting about 29 mpg average mix. I drive mostly highway though. But when I was driving mostly local, I get around 26-27 mpg. But the mini gets pretty good mpg because of its low end torque. In stop and go traffic, I shift a lot and I shift normally around 2k. and I am already in 6th gear at 40mph lol .
I red line the car about twice or sometimes more depending on the mood every week just to hear the supercharge whine. Its good to push the engine every once in a while. If I am doing that I dont care what mpg I get lol.
06 MCS a
Electric Blue Owners Club
06 MCS a
I have a 06 MC in response to the rim diameter being a factor it is!!! An 18in rim has a lot more rotating mass that has to be pushed. Even if the rim is an after market and weighs the same as a 15in it still has changed the gear ratio of your car making your gears essentially taller. I get 22-28mpg city and 30-45mpg highway at 89mph at 90-100mph I get 28mpg, 100mph-130mph 27-20mpg, 130-140mph 20-16mpg this test was made while running against an MCS. Make sure tire pressure is up , do not use AC if possible, and on highway keep windows up and sunroof closed or cracked only a little bit. I personally drive the heck out of my car constantly pushing it's limits. I only use shell, sunoco, BP, 91 octane and every other fill up I use marvel mystery oil.
Traveling 100 miles on a 15"... the 17" rim may say you only traveled 92 miles.
Again this is based only on what your odometer is calibrated for.
