Fix for shift knob popping off
Old 06-29-2003 | 05:17 PM
friedduck's Avatar
friedduck
I let a friend take his family for a ride in Coop last night and of course the shift **** came off again (kinda embarassing.)
I took some o-rings (two of 'em) labeled size 5/8" x 13/16" and put them around the two little tangs that hold the **** on (look inside the ****) so that when replaced on the shifter the fit isn't so flimsy.
When replacing the **** it was much tougher to snap on, and it'll take a lot more force to remove now. Time to go test
Jeff
ps: Also save a sec or two when autocrossing as you won't have to reach down to put the **** in the cup holder during your run!!
Old 06-29-2003 | 05:25 PM
mightyMiniz's Avatar
mightyMiniz
Try a Whalen ****.....
Sounds like your stock **** is a whole lot of effort.
Old 06-29-2003 | 05:28 PM
vespa's Avatar
vespa
Good fix but you could just have it replaced under warranty. Mine grips like a crocodile. I suspect there was an early design or bad batch that has apparently been corrected.
Old 06-29-2003 | 06:56 PM
friedduck's Avatar
friedduck
Oh--didn't know about that--thanks for the head's up.
The whalen stuff is beautiful--I'll get one in time.
Jeff
Old 07-05-2003 | 12:19 AM
MINIJC's Avatar
MINIJC
friedduck:
I got my shift **** replaced under warranty. The new one worked fine and had no problems after that.
But I just got a Whalen Shift machine... and let me tell you... it is nice!
If I was you I'd first have my original shift **** replaced under warranty and then I would get a Whalen Shift Machine...
Good luck!
Juan
Old 07-06-2003 | 11:22 AM
Normalizer's Avatar
Normalizer
More kudo's for the Whalen.... overpriced but man what a nice ****....
Everbody I've shown my **** to has admired it, and they love pulling it off.
Oh wait a minute, what were we talking about?
Old 07-09-2003 | 01:43 PM
Rocketboy_X's Avatar
Rocketboy_X
Ahhh, the joys of molded plastic......
Unless you test something like this frequently, you're bound to get bad batches...temp off a few degrees, too much moisture in the mix, press time off a tad, ad nauseum...
Rocketboy_X
07-16-2020 01:54 PM
chandler_vt
04-29-2017 09:08 AM
cawwwtun
05-03-2016 09:03 AM
jziran
08-24-2015 05:50 PM
WayMotorWorks
08-19-2015 09:04 PM
