Vibration when Accelerating
I just bought my '03 MC and I thought it had a tire problem. I took it to a tire shop and they said those were new. I changed the motor mounts and a part that goes on each side that's called control (something) which I don't remember.
The problem is that when I accelerate the car vibrates and when I'm not tuching the gas it runs as smooth as new. When I get to about 35-70mph it is horrible. although, once I get to 80/90mph it calms down, but still vibrates.
Anyone ever heard of this problem? PLEASE HELP ME!!!
OTHERWISE I'M SELLING MY MC!!!!! I LOVE IT BUT I CAN'T STAND IT!
Sounds like you need a competent mechanic. I've never found anyone at a tire shop that knew much about cars beyond tires. To start changing motor mounts and other parts w/o first diagnosing and tracking down the problem is also not an effective strategy.
Most people don't want to pay for diagnostics and mechanics wind up swapping parts just to try to fix the situation but that rarely fixes things.
Where are you located? I'm sure a Mini owner in your area can direct you to someone competent.
Its hard to guess from your description but sounds like you either need a good wheel balance or a blown shock or something else altogether.
Macsplinter (04-25-2020)
Bad CV joint is my guess. When something happens to a CV it manifests it's self as a pretty severe vibration under load. But without being there to test drive it, it's only a guess. But, I'm am in agreement with fullcolapse. It definatly sounds like something wrong with your axle or axle related component.
I would go with fullcollapse on this one...as with mine, I have a MCS. It started the vibration after I lowered it and at the same time the check engine light came on, telling me something is wrong..from what I can tell so far, without getting a diagnostic, its the MAP sensor..but won't know till later this week..then i will know 100%..good luck with your vibration..I know it can be annoying..
Eurothrasher (04-25-2020)
