Is this part failing?
Hi All,
Pls refer to the attached photo, is that part failing? If yes, does anyone knows what is the part number for that part? Izzit number 3 (refer to below link)? But which one?
- 22116763259
- 22114046186
- 22116778610
http://www.realoem.com/bmw/showparts...98&hg=22&fg=05
My car is MINI ONE CVT production month 05/2004
Thanks alot.
- 22116763259
- 22114046186
- 22116778610
Thanks alot.
It's not going to cause any problems other than possibly some extra vibration if you let it go for a little while. Many owners don't even notice the leaking mounts until they've been leaking for hundreds or thousands of miles.
Replacement is pretty straightforward, although it would be a good idea to put a floor jack underneath the engine to support it while you're removing the passenger-side mount. Also, I've found that the #4 bolt in the diagram you linked to can be a pain to remove on some cars.
and make sure you have the E12 socket. I found that the extensions and swivel adapter really helped with that bolt. Have fun!
Indimanic
08-19-2015 12:08 PM
R50/53 Replacement AC compressor??
PrimePower
08-16-2015 07:29 PM
