Strange noise when first move my MINI every morning
Dear all. I just wanted to share something strange when I first move my MCS 06 every morning. I heard a strange sound whenever I move the first 2 or 3 feet in 1st gear or reverse. Its like the sound when you move a wood chair! or something like that. At the beginning I thought that it was the brake pad but I'm realizing that the sound is coming from the clutch, i don't know. Anyway, after a few seconds the sound disappear and its only during the first gear or reverse. The dealer just check it but the sound is coming whenever the car is out of the garage or first move. Any idea of what could be the source?
There are many in the forum who have a similar sound. My 2004 MCS also had it. In my case it was an oil leak onto the clutch plate and flywheel. The dealer knew what it was right away, replaced both the clutch plate and flywheel and fixed the leak. No more squeek. Others have called it a bark or screech. However you describe the sound, the symptom is the same, sound is present when first starting out in the morning and goes away very quickly as the oil is scrubbed from the clutch plate. Mine was fixed under warranty over a month ago and has been gone ever since.
Mike
Mike
on
Mine did it for two years and then one day it stopped. It is a clutch problem. Too expensive to fix for me and the dealership said that the warranty wouldn't have it fixed because it is an operator failure issue. The sound on my car happened at the same time yours did and at streetlights. The sound morphed into a small squeak or chirp and then eventually stopped. Maybe it will do the same for you?
Thanks to all, I'm not feeling alone here. I think that at the next maintenance schedule I'll leave the car there to be tested. (Because they say that the car has no problem if they didnt hear the noise!!)
Just one more thing, does this is life threatening or I just can live with it until next schedule?
I have had it 3X and my wife's MINI has had it once. If you mean an UURRTT sound like a belt slipping than it is the clutch. We have a dual mass clutch that has bushings in it. When those bushing get a "glaze" on it, it "slips". I have had my local dealership replace the clutch and flywheel under warranty with no issues. Now, it will ALWAYS return and the only way to get rid of it is an aftermarket clutch and flywheel. I have about 400 miles left on my warranty and had them replace it just recently.
There is no safety problem or anything like that. So, if you can deal with it, then don't be worried.
It's the clutch!!
Fellas,
I had the same noise problem with Maggie (06 R53), however, I thought it was, because my garage is in the basement, that I was feathering the clutch too much climbing up out of the garage in the mornings. After about 2-3 months of this, I started to notice more resistance through the clutch pedal and then a rubbing with friction sound from under the front left side of the engine. Amazingly enough, my Netherlands BMW company figured out that the clutch was failing and completely replaced it, under warranty!!
Therefore, having watched several of these threads since the summer, I heartily recommend to ya'll that you get with your dealers about replacing the clutch. Not to add insult to injury but I took Maggie to the Nurburgring (Nordschleife) today to finish "breaking in" this new clutch!!
Cheers!!
Cheers!!
on
I have the same noise on my 06 MCS, but not every morning. It's harsher and lower pitched than brake squeal, and it's only present when the weather's damp. Am I understanding the previous statements correctly when I say that it's only bad if it gets worse?
Glad that I'm not the only one... Dealership is 2h away, so leaving overnight is not really an option. Wisdom of the forums is much more convenient. =)
very common issue with manual shift minis. goodluck getting your dealer to actually do someting about it. in most cases, once the car has warmed up and has been driven, the noise no longer sounds. so by the time you drive to the dealer, they treat you like the boy who cried wolf and say they cant fix it because they "can't replicate it".....jerks.
clutch noise
Our mini (2006 MCS) does the same thing - it started at 3,000 miles and is in the shop now. As the dealer was taking the car into the carwash, they heard the clutch noise/groan/squeal/OORT/grind we were complaining about. They said they may have to replace the clutch. I'm guessing that's what is happening now since I've not heard any news that its ready. We'll know sometime today. Greg
This is the same problem that plagued my former '02 S. Dealer knew what it was(flywheel) and replaced once before my warranty expired. After warranty, I had it replaced by Mini 3 more times. The parts were warrantied for 2 years so it still didn't cost me a penny. It's still aggravating because of the continued visits to the dealer though for such a senseless recurring issue. i wondered why BMW would just replace the manufacturer of the flywheel???? Nope, just kept putting the same one back in. I was told however that this "defect" does not detrimentally affect the car, other than the noise simply being present.
Attached is my service sheet for perusal if interested...Anyone know what the out of pocket expense would be on this replacement?
Mike
Mike
I had mine replaced just before warranty ended for the same issue, it was at about 48k miles
Mine's been doing this for a while since I bought the car a year ago with 12,000 miles. Now at 35,600 miles and in the shop for a new clutch.
on
If yr dealer balks--or tries to blame operator error, which is TOTAL BS, then complain LOUDLY to MINI-USA.
PS mine was NOT due to an oil leak, for it always happened in 1st gear when the clutch was under load, warm or cold. Dealer had no clue what caused the glazing. They just replaced both, no hassles no problems, and tacked on a 2 year p/l warranty that extends past my OEM warranty (extendeds do not cover clutches nor flywheels). I love my dealer.
Clutch Squeal
If your car is still in the warranty period you need to take it to the dealer NOW!! The issue sounds just like mine and it turned out to be the rear main seal is leaking onto the clutch and it is covered under warranty. I have had two new ones installed for no charge...one under the warranty and one under the parts warranty. Both were done 15 months apart as the rear seal leeaked even after the first replacement.
I will say that the MINI dealers are very supportive of all warranty issues, especially at FLOW Motors in Winston Salem. The parts warranty is for aperiod of two years and unlimited mileage...no questions asked.
Good luck.
Good luck.
