oil around valve cover
The first thing that comes to mind is that your PCV valve is not operating properly. If you are not venting the pressure has to go some place and usually the weakest link is the valve cover gasket. Do you have an OCC installed? Some people have tied both sides together and have run into this problem. I believe the best way to do the OCC install is to just put it between the PCV valve and the gray line. Also I have seen some examples of PCV hoses being pinched because of the location of an OCC.
In any case I would first check to be sure the PCV valve is operating correctly.
Steve
Steve
on
Lex2008
08-16-2015 08:33 PM
