I think my hood scoop is melting...
#152
#155
mine is doing that also im only 1070 miles in waiting 4 it to get worse then heading to the dealer and try to fanagle a carbon fibre hood scoop from em anybody think the ram air scoop and cai will help with the problem?
#156
Yes, it's melting / warping. Carbon fiber scoop maybe the best solution. Order the one that comes with the JCW Aero kit and it should fit okay. I believe it can be painted, if you do not like the black color.
#157
I saw another thread on NAM that someone was having issues with a chrome scoop and they thought it was due to the heat. The "chrome" portion that covers the plastic was starting to shrivel up and contract.
#159
on
I'd like to know why the "open" scoops are having just as much trouble as the "closed" scoop I have on my very early R56. I thought that was supposed to fix it.
Has anyone completely removed the grate, and still had trouble?
I'm not thrilled with the idea of having to spring for carbon fiber myself, and I'll bet no one will be able to get one from MINI.
While I'm on the subject, has anyone had trouble with the paint itself on either the hood or the scoop? You'd think those high temps would cause some cracking or something along the line, wouldn't you?
#160
I know that no one likes to spend money to fix something that the Mfg. should take care of but we had seen so many melted scoops including ours that we had to do something . This is a possible option for some of you .
Randy
M7 Tuning
This is the listing on our site .
http://www.m7tuning.com/parts/produc...roducts_id=137
This is a thread going here on NAM by some members that have installed the unit.
https://www.northamericanmotoring.co...d.php?t=148539
Randy
M7 Tuning
#161
Maxmini,
So did these covers work as far as NOT causing your new scoop to melt?
How many months have you tested the cover with the new scoop on?
Are you using a Carbon fiber scoop or the normal one to do the testing?
Have you had any turbo issues due to having it all covered up with the cover?
Do you think it would be better to use those heat wraps to cover up the turbo, or is using your plate cover a much "Safer" solution?
Thanks for your time, Maxmini.
#162
All good questions and I will try to answer them as best I can.
Maxmini,
So far we have not had one report of a scoop that has had any issues after the install.
Over 6 months with the first prototype. Here in sunny So Cal I think that is a good test. We had a customer drop by with his brand new , under 300 mi, R-56 with a droopy scoop so it can be said that we are in a rough environment here heat wise.
We have tested it both ways on multiple cars .
Because the turbo is NOT all covered there have been no turbo issues.
We feel our solution is a better one than the complete wrap. It would be interesting to see a Mini service writers opinion of the complete wrap system.
Thanks for your questions,
Randy
M7 Tuning
Maxmini,
Randy
M7 Tuning
#164
That is my concern as well. While my stock scoop has not melted, it does get very hot, hitting 200+ degrees. I have recently installed the JCW CF scoop, and would like to protect it with the M7 shield which appears to be a very elegant and easily installed solution. However, my concern is that the dealer may take issue with the shield. I considered just removing it whenever the car requires service, but after reading the installation instructions, the double-faced tape makes removing and re-installing seem less tha ideal.
#165
PS Check the uses of carbon fiber from sailing masts and so on.
#166
Why do you think a CF scoop will melt or warp? As far as I know none of the scoops with this problem are CFs, if I am mistaken please correct me. MINIs with JCW CF scoops please chime in, your input would be appreciated. It's my understanding that the CF is made to withstand much greater amounts of heat than the stock plastic.
#167
When that happens have it painted to match the car. Race cars with carbon fiber body parts are painted all the time. But, I've heard and read about the discoloration, and it was also stated it could be cleaned and restored.
#169
Unbelievable, mine started slowly deforming as well, I bought it 1 month ago exactly (have 1500 miles now). I have clear bra over the scoop as well! This will cost me more later...
I knew I should have gotten base Mini Cooper, not the S. You pay over 22k for a car, you expect that manufacturer would use a quality material.
Not sure what to do, since Mini doesn't seem to have solution to this besides replacing the poor quality scoop with same one..
#170
I posted a maintenance question earlier, here is the link:
https://www.northamericanmotoring.co...d.php?t=148443
#172
on
I personally wouldn't keep this problem from letting me enjoy the S. MINI WILL replace the scoop, after all, and eventually will find a fix. And your scoop might not dip more than wbarnhill's or mine. Yes, technically it is deforming, but I'd sit tight until you see how far it goes. My car is 1 1/2 years old (25,000 miles), and it looks like his.
#173
#174
#175
