1-2 shift scraping noise - linkage?
Old 02-10-2008 | 07:40 AM
chickenplucker's Avatar
chickenplucker
Anyone else experienced a scraping noise when shifting from first to second? It only happens when cold and only for the first 2 or 3 shifts. It's definitely a linkage issue because I can feel it in the shifter handle.
Just curious if anyone has had this issue addressed at the dealer, what caused it, and what they did to correct it. Thanks
Old 02-13-2008 | 10:29 AM
CaptainCradicles's Avatar
CaptainCradicles
I might have a similar issue. It only happens when it's cold out. Scares me to think that something could happen to a car with less than 600 kms. I'm going to make an appointment and look into this as well.
Old 02-17-2008 | 03:08 PM
kimmc's Avatar
kimmc
I had this issue and ended up getting a new transmission (under warranty - it was an issue with the syncros.) Do a search in the stock problems issues forum. Several people reported this.
I'd take it to your dealer sooner rather than later, and don't let them tell you it's just a break-in issue.
Old 02-17-2008 | 03:12 PM
chiliredr56's Avatar
chiliredr56
Right on kimmc , sounds like a syncro problem to me . Seen lots of RX-8s with the same problem were I work .
Old 02-18-2008 | 01:23 AM
CaptainCradicles
kimmc,
Can you describe the problem more. For me, it only happens the 1st time I shift from 1st to 2nd in cold weather. Sounds like I'm scraping the gears against the left side of the gate. I have been really easy on the car during the break in so I don't understand why this could be happening.
lweaver
09-17-2024 09:22 AM
Supertractor3
04-07-2017 12:16 PM
rob&JCW
09-10-2015 01:06 PM
SneedSpeed
09-02-2015 06:34 AM
