Cold start chatter
Old 02-22-2008, 08:50 PM
checkercoop's Avatar
checkercoop
checkercoop is offline
Originally Posted by russr
If that guy who owns the Peugot 207oc is correct, then this problem would affect the MC too right?
Yeah but it only seems to be affecting the S...the non S and S motors differ and this difference seems to be making it happen on the S and not the non S...i do hope they find a fix tho because that would put a horrible image on MINI if their engines died right after warrantee
  #327
Old 02-22-2008, 11:19 PM
msh441's Avatar
msh441
msh441 is offline
Not necessisarily... the issues primarily appear to effect the head and it's attached components.
The design differences between the MC Valvetronic set-up may be keeping more oil in the head... unlike the MSC VANOS only system.
Originally Posted by ClubmanS
This is great... Basically owning a second gen MINI beyond the warranty period is akin as to playing russian roullette.
On the up-side... identifying a root cause at least lets the engineers start work towards a possible solution. Oil starvation (if thats what it turns out to be) can be addressed various ways. The nice permanant-type solutions that ensure the issue will not return.
I'm 500 miles into the new engine and it purrs like a kitten. Not to say it'll last... but for now .
Got two cold/sunny days this weekend to spend some quality time and remember why I love this car so much. Two long twisty day drives followed by a coffe-house visit with car friends at the end.
If they end up acknowledging the issue, identifying the cause and developing a fix... I think it'll be a great car to own long term. If not... .
  #328
Old 02-23-2008, 12:32 AM
SPECKY's Avatar
SPECKY
SPECKY is offline
Mine went in on thursday and it rattled for the dealer !!!!!!!. Needless to say..... THEY KEPT IT IN. They think they may have fitted the wrong (ie older) new engine unit !!!!!! YEAH, RIGHT. Not heard owt since.
  #329
Old 02-23-2008, 05:47 AM
korby's Avatar
korby
korby is offline
They should give you two new cars for your trouble Specky !
  #330
Old 02-23-2008, 01:12 PM
SPECKY's Avatar
SPECKY
SPECKY is offline
I wish.......... I'll just av to keep runnin..... "THE LOANER" !!!!!
  #331
Old 02-24-2008, 05:28 PM
russr's Avatar
russr
russr is offline
I know it's a little too early to tell, but curious if any '08 owners have experienced this problem yet.
  #332
Old 02-24-2008, 06:45 PM
uzun's Avatar
uzun
uzun is offline
I think I heard the rattling noise for the first time in my 07 MCS today too. I had parked the car in the garage at around 10 pm last night (Saturday). I heard the noise when I started the engine at around 5 pm this afternoon (Sunday). It was definitely not the usual engine start-up noise I was used to. I should also mention that earlier today, around noon, I briefly started the engine two times to move the car a bit to clean its interior. The engine did not run more than a minute or two both times. I don't think I noticed a strange noise during those short runs. My car has about 4700 miles on it. The outside temperature was about 70 degrees today.
  #333
Old 02-25-2008, 09:13 AM
r56mini's Avatar
r56mini
r56mini is offline
Mine acted up for the first time this morning. It has almost 9000 miles and it was in the garage so the temp was around 60°F or so. Damn...
I didn't run it on Saturday and I moved it about 5 yards on Sunday to clean the interior.... And it did that this morning.
I guess moving it a short distance and leaving it somehow causes it?
  #334
Old 02-25-2008, 09:20 AM
SPECKY's Avatar
SPECKY
SPECKY is offline
2 more on the list then !!!!
Just got back from stealers and they dont know how to fix it !!!!!!
So i'm no better off now !!!!!!!
  #335
Old 02-25-2008, 10:37 AM
TK76911S's Avatar
TK76911S
TK76911S is offline
Hey Folks,
Though I am not a sufferer (yet), I am extremely sympathetic to those affected and concerned for my car. Seems inevitable. How about the following "COLD START REGISTRY:"
MC or MCS:
Build Date:
Date at First Noise:
Miles at First Noise:
Temp at First Noise:
Any Resolution (y/n):
Any Particular Issues:
Cold Start # (self-assigned based on last # taken):
No pride in authorship. But does everyone agree we need to get organized?
  #336
Old 02-25-2008, 10:39 AM
SteveS's Avatar
SteveS
SteveS is offline
Check your local lemon laws. Repeated unsuccessful repair attempts may entitle you to rescind the contract or get a new vehicle. The noise is a mechanical knocking. This is bad for the engine. If it is a regular occurrence, there is most likely some unusual or accelerated wear occurring, which may not manifest itself until after the warranty expires.
  #337
Old 02-25-2008, 11:43 AM
Event-Horizon's Avatar
Event-Horizon
Event-Horizon is offline
Originally Posted by Event-Horizon
Ok, I think it’s a good idea to create a database of sorts about "cold start" noise. Maybe this way we can find a common link with the problem. Any other information that we should add?
Cooper S, 6-Speed Manual
Build Date: October 2007
Miles: 3500+
Duration: 30 seconds to 1 minute
RPM range: 1500-2000rpm
Ambient Temp: low 30's first time, 18 degrees second time.
Oil: Factory Fill, Castrol 5w-30, oil level full
Any other relevant information:
Car parked with the nose of the car in a downward slope both times. The sound can best be described as a growling, clattering, or rhythmic tapping. This cannot be piston slap at this speed because the frequency is too low. At 2000rpm, piston slap would would happen over 33 times a second. This is valve train related for sure due to the half-speed frequency of the sound. This means that at an engine speed of 2000rpm, the cams are spinning at 1000rpm or roughly 16 times a second.
I tried this before
Btw, 0w-30 Castrol is still working well. No cold start noises so far on this oil change. Car is very easy to start and drive in the morning. Very quite too. I believe this oil flows much easier allowing the cylinder head to receive proper lubrication.
  #338
Old 02-25-2008, 11:53 AM
Loony2N's Avatar
Loony2N
Loony2N is offline
I may have missed it, but is the downward slope of the park angle pretty much a requirement?
  #339
Old 02-25-2008, 11:58 AM
TK76911S's Avatar
TK76911S
TK76911S is offline
Event-Horizon,
I like your parameters much better than mine, except there is no place to begin to keep count
So you are CSN #1!
Next?
I tried this before
  #340
Old 02-25-2008, 12:03 PM
uzun's Avatar
uzun
uzun is offline
I tried this before
Assuming the 0w-30 oil fixed the problem for good, what are you planning to do when you take your car to the dealership for your free oil change? The dealership will want to use the regular MINI-branded 5w-30 oil. Will you take your own 0w-30 oil to the dealership and insist that they use your 0w-30 oil instead of their regular 5w-30?
  #341
Old 02-25-2008, 12:22 PM
Event-Horizon
If it is in the spring/summer months, then the 5w-30 dealership oil change should be fine. If it's in the winter months, I may bring my own oil for them to use.
  #342
Old 02-25-2008, 12:24 PM
r56mini's Avatar
r56mini
r56mini is offline
It happened in the garage for me. It is not the weight of the oil that caused it as far as mine is concerned. It sounded like a bad chain saw. The noise was worst when the rpm was up to 2000 rpm. I had to go to work and per owner's manual no warm up so I drove off. The noise went away after about a minute from the start of the engine.
Build date: June 2007.
8800 miles.
MCS manual.
  #343
Old 02-25-2008, 12:30 PM
Event-Horizon
Post your info here: https://www.northamericanmotoring.co...d.php?t=130308
Cold Start Issues database thread
  #344
Old 02-25-2008, 12:35 PM
TK76911S's Avatar
TK76911S
TK76911S is offline
To all affected by Cold Start Noise, please go to NAM "COLD START DATABASE" https://www.northamericanmotoring.co...d.php?t=130308 and register so there is a single bank of info for MINI to see and use hopefully to all our mutual benefit to fix the problem(s). Thanks.
8800 miles.
MCS manual.
  #345
Old 02-26-2008, 10:50 AM
Birdman's Avatar
Birdman
Birdman is offline
No. It has nothing to do with the slope. More to do with outside temperature, and a cold car (sitting overnight...).
  #346
Old 02-26-2008, 11:19 AM
russr's Avatar
russr
russr is offline
I see people posting that they have this problem when it is 70deg outside. That's not exactly cold.
  #347
Old 02-26-2008, 11:21 AM
Loony2N's Avatar
Loony2N
Loony2N is offline
It doesn't have nothing to do with the slope, because that is a common situation reported by posters. And it is definitely not contingent on temperature, although, if oil starvation is the cause, it is going to be more noticeable when the temperature is lower.
  #348
Old 02-26-2008, 11:26 AM
prb44t's Avatar
prb44t
prb44t is offline
I keep a notepad in the car. And every time I start the car I note, the date, time, temp, time since last start, and angle the car is resting at.
I have dumped the info into Excel and can say for me at least, there is a correlation between slope and the noise. If the time since last start is less than 5 hours, it seems like slope makes a difference. I don't understand why, but that's my data so far. Small sample set so take it with a grain of salt...
  #349
Old 02-26-2008, 11:49 AM
Birdman's Avatar
Birdman
Birdman is offline
I'm on LI, you'd be hard pressed to find a slope of anykind. ;-) I park on a dead flat driveway and parking lot at work. My data shows only one thing: COLD temperature. 95% of the time, it must be lower than 30 degree's and the colder it is, the more likely it is to occur.
It occurs 100% of the time for me when the temp is below 20. When it is between 20 and 25, it occurs 50% of the time. When it is between 25 and 30, it occurs 15% of the time. From 30 to 45, it occurs 2 to 5% of the time. It has never occurred above 45.
  #350
Old 02-26-2008, 11:55 AM
johned206's Avatar
johned206
johned206 is offline
I read the article in Motoringfile and went to the site of the Michigan Mini Club on the net as recommended. Some good information there on this issue provided by some apparently well qualified engineers. If you haven't checked it out I suggest you do so. www.michiganmini.org
Quick Reply: Cold start chatter
