Moss MINI High Flow Intake Filter
I installed the Moss intake filter today, and I must say, it sbsolutely roars! I installed it even though I already had a Pipercross foam intake filter installed, which was great, except the oil used to filter out fine particles dripped all over the transmission case, making it look rather dirty.
It's really hard to compare the two. The Moss filter assembly looks a lot better first of all. Mine is anodized red, and really looks sharp. Plus, everything from the filter to the hose connecting to the throttle body is included, replacing the plastic OEM hose with an aluminum one. Installation was a cinch too.
But the best part occurred when I took it for a test drive. The Pipercross had a nice growl, but this thing positively roars! I pulled up to a loud rice burner, and not only did I smoke him, but I was louder too! Very impressive, and of course the filter is reuseable. It really dresses up the engine compartment nicely. Highly recommended.
Jason
Jason
>>Can anyone tell me if putting one of 'dem filters in voids the warranty?
>>Many thanks,
Man, the warranty thing should be the first thing on a FAQ... you will only void your warranty on a specific part if the aftermarket part is found to be the cause of damage. So, unless the problem can be traced to a bad air intake, you're fine....
Rocketboy_X
>>Many thanks,
Rocketboy_X
07-16-2020 12:54 PM
08-10-2015 01:59 PM
Ambient Thermal Management
08-07-2015 12:27 PM
M7Speed
08-06-2015 01:48 PM
