More spark plugs woes... stripped?
So, I went this morning to go put the plug back in since I didnt have the ratchet for it yesterday and discovered that the damn thing just didnt want to go in!!!
All of the threads on the plug were perfectly fine... however, I just couldn't get the plug to start threading. When I looked down with a flashlight, I noticed that it looked like there might be some metal shavings down in the cylinder head....
So, 2 questions.
1) Is there a simple way to safely re-thread it? If not, how much do you think I might be looking at to get it done?
2) WTF could cause a plug to blow the frickin threads off?
So, 2 questions.
Ouch is right.
I guess these things are not cheap plus you pay for someone with the expertise to put darn thing in.
I just had to have an insert put in for my right rear trailing arm which stripped when trying to do an alignment. (the toe in was way off.) It's held on with three special bolds. They have a slight triangular shape design to lock itself in and is supposed to be put in with 75 ft-lbs of torque. One of them must have taken out the threads on the way in. I ended up sending the car to a local shop that specializes in threaded inserts and does a lot of work for the local aerospace companies. (Boeing Anaheim for one.) In all it cost me $420.
It hurts to pay that much but you want it done right so...
Paul
Paul
Hay...
most shops charge 6-8 hours for a head removal replacement, and there's about $100 for the gasket set. A couple places quoted over a grand without even the cost of the insert. That was just to take the head off and put it back on. So I guess it's relative. Yeah, $350 is more than I wanted to spend, but a lot less than I feared spending. I was happy to pay the bill.
Matt
Matt
Questions About Backtap...
Do I have to remove the cover for the cylinder head (and thus the fuel rails, intercooler since I have alta, and any other crap up there) to get the tool in there? When the backtap got here I thought to myself... holy crap that thing is too short. Sure enough, it is :(
I have never removed the head cover on the MINI... is it a pain in the #@* ?
Shockingly easy...
just a bunch of 12pt bolts. Get acess, and just run around the thing with a socket wrench. The gaskets at the top of the spark plug tubes make it not want to come up to easily, but a little determination is all it takes.
Matt
But you will find that the tube is still in place. It just is press fit onto the head, but I've never taken one off.
Matt
eliseo1981
05-10-2016 05:19 AM
09-02-2015 09:05 AM
