OK, I Am Officially Leaking Oil!
ok, i am officially leaking oil!! i come out every morning to see an fresh oil spot under the front left side of my car. if you were standing looking at the car from the front, the oil spot would be on the left passenger side about 1 foot in from front and 1 foot in from wheel. someone please tell me what is over there? is that where the oil drain plug is? could mine have been stripped? i cant imagine an new engine with 18000 miles on it already leaking oil,so it has to be the oil drain plug. but i just need to know if thats where it is.
1 ft. from the passenger side wheel and 1 ft rear of the lip of the air dam is just about where the drain plug is. Have you had your oil changed? Did they forget to put the compressible copper washer in place, didn't use a new one, or didn't clean the area properly?
It could also be a leak around the oil pan or from somewhere else and is running down to that location.
any one figure this out????
has anyone figured this out.
I've got the same problem. I jacked up hte car and its running down the passengers "A" arm. and splattering all over the underside. The drain plug is not lookin comprimised.
I could use the help too?
I can usually crall under the car and check it out but I just ripped a ligament in my knee so I can't get under there as easy.
Lex2008
08-16-2015 08:33 PM
