2nd Hand DME
on
2nd Hand DME
I have conflicting reports, so I was hoping to get a definite educated answer once and for all.
Is it possible to program a used DME for a another MINI within the same model, age, etc?
Sounds simple enough right? I know that if it is possible, it must be done by a dealer, but that is where things start to get messy. If you had it done, where, who?!?!
The DME has also been referred to as:
1.) ECU
2.) ECM
3.) EMS / EMS2000
Discuss.
1.) ECU
2.) ECM
3.) EMS / EMS2000
Discuss.
on
on
on
on
Ok, so it is a one way process then. To restate:
1.) A used DME can be re-programmed for an existing car
2.) There can be only one operational DME / car
Is there any special trick to getting this to work, or is this a standard process that any MINI service center should be able to perform?
Thanks again.
Thanks again.
Thanks again.
Thanks again.
IQRaceworks
53
06-28-2024 07:29 AM
Alpha Motoring
10-01-2015 10:30 AM
Emnotek
09-29-2015 07:37 AM
