Valve Stem Cap PROBLEM!
Monday afternoon i thpught i might just the pressure in my tires just to make sure everything is topped up, and noticed that I couldnt remove my "S" stem caps...I tried all 3 other tires, and could remove them either...after feeling like such a loser because i couldnt get them off, i took to my dealership to service, and they had to destroy them and even cut one stem off in order to remove them....techs told me that they are seising(spelling?) up due to the run flat sensors...EVEN THOUGH they are MINI products that they're selling...and they told me next time i put them on, they would not remove them with no charge =/ not cool...
Are the plastic caps an OEM MINI part? If so, any chance you would know the part numbers, or have any details?
I think the original "mushroom" plastic caps are ugly, but on previous threads I've heard that metal caps should never be used, as the aluminum valve stem reacts with any metal cap, even an aluminum cap. Acura recently had a recall of the aluminum caps they used on their aluminum valve stems, which were seizing, resulting in the same issues the OP had.
I would be interested in plastic logo caps, but all I've seen are the metal caps.
MINI wings logo-part number-36 11 0 429 651
"S" logo-part number-36 11 0 429 652
Checkerboard-part number-36 11 0 429 945
Union Jack-part number-36 11 0 429 946
Nope, I was referring to the ones I listed above. They are plastic and are specifically for MINIs with the tire pressure sensors.
iPhone pic...
The plastic ones are on the right.
They look just like the metal ones, but the shank portion on the plastic ones is shorter(definitely too short for a basic rubber valve stem).
You will be able to tell the difference in weight if you have both in your hands.
Hope that helps.
Hope that helps.
Yah that's what my dealship told me as well....they dont carry them but they ordered and comped them bc they had to use vice grips on 3 and just cut the stem off on the other...so i will be interested to see them out of the package and up close, i will get pictures on here once I have them...should be saturday or so..
Just had to use channel locks tonight to remove my valve stem caps!!! Aaaagghhh!!! Thank goodness I did not have much damage to the stems, just had to chase and clean the threads a bit.
Then found this link; would have been nice to know the metal caps did not my TPMS sensor stems. The dealer sold them to me, said no problem, they'll fit....not! Hopefully the parts dept will make a fair adjustment for me, when I order/buy the replacement plastic logo caps. Thanks for the parts #s and posts....NAM with great reliable information, as always!
DO NOT USE ANY METAL CAPS ON ANY TPMS sensors. I run a tire/automotive store. It does not make any difference on the vehicle manufacturer. They will all seize on the stem. Do not use any other substance on the threads either. The materials used on the TPMS sensors are different then regular rubber valve stems. The cores are nickel and the caps should only be plastic or plastic lined. A cap should always be on as well. I can not begin to tell you how many caps we have cut off, and how many sensors are ruined from the lack of a cap. However, if a metal cap does seize on the stem, a dremel tool can be used to lightly slot the side of the cap and release the cap. Try not to hit any of the threads. The only good thing about the Mini's is that the stem is sold separately of the sensor and Mini's are self registering.
What is the BERU part number for the stem/inserts for the 2007-2009 MINI, anyone know? Getting my new tires in a month, powder coating the wheels, and since the threads are a liitle tweaked from the metal cap fiasco, I am also replacing the stems at the same time. Should be "BERU part #59.0342 Green Insert", can anyone confirm the part number? Any help is apprecectiated.
Kimolaoha
07-05-2023 01:04 PM
07-16-2020 12:54 PM
