clutch squeek help
clutch squeek help
hi
i have a rubber sounding squeek from the clutch pedal.
i have traced the sound to the black rubber boot located at the bottom of the clutch pedal.
can ayone tell me if it is safe to spray lube inside this boot.
my car has 28000 miles on the clock and my clutch is fine.
Just had this problem fixed on my 06' MCS. Fortunately, mine was covered under warranty. They replaced the clutch assembly, as well as some bushings in the bell housing of the transmission.
I would bring it into the dealership, they are usually pretty lenient with cars with mods (so long as you don't have anything that would affect the clutch).
Best of luck!
Best of luck!
drrigg
05-27-2022 03:31 AM
eliseo1981
11-02-2015 11:24 AM
unxpectederror
10-22-2015 12:16 PM
10-01-2015 12:13 PM
09-28-2015 09:13 AM
