Do I need an alignment? (symptoms)
Symptoms:
TIA.
- The steering wheel's center seam is between 11 and 12 o'clock.
- When coming to stops (stop light for instance) on crappy roads in the city I notice if I take my hands off the wheel the car pulls to the left.
- On the highway, cruising along, the car will slowly, ever so slightly begins to favor the left.
TIA.
good place to start
Symptoms:
TIA.
be careful tho and ask around. not all alignment shops are created equal. great equipment in the hands of a poor operator can give you numbers that look good on paper but are actually meaningless and your ride could get worse.
finding a good alignment man is like finding a good dentist. hold on to 'em
Check tire pressures...
then find a really good alignement shop. REally, alignment settings for the performance oriented aren't a one size fits all. After you find a really good shop, talk to the tech that works on your car about how you want it to drive. The first one will be a "baseline" set up, and every year or so, talk about what you like or don't like, and he or she will read your tread wear, and you'll decide a way to go with the alignment specs. Make sure you get the same tech each time.
At the place I use, the same guy has been aligning my cars for about 10 years....
Matt
Matt
Bunch of info. here. Sorta helpful: https://www.northamericanmotoring.co...d.php?t=125235
If anyone cares.
If anyone cares.
daonlyillwiz
09-28-2015 07:04 AM
daviday
09-25-2015 01:31 AM
