Seat Stuck in one position
Old 08-17-2003 | 07:26 AM
MiniPilo's Avatar
MiniPilo
Hey All,
I have been working on my stereo system, and when I put my seat back in, I find that it will now ony fold up and slide up to let passengers in, then slide back and lock in one position. It slide front and back still, but the recline is stuck.... and recomendations on how to fix this? I am going to the dealer on tuesday for an unrelated issue, but I would like to get this fixed today if possible.
Dan
Old 08-17-2003 | 08:03 AM
smcfamily's Avatar
smcfamily
Have you tried resetting the seat? Here's a link that shows how:
http://www.r53w11.com/frontseats.htm
Hope it helps.
Shawn
Old 08-17-2003 | 10:02 AM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
I thought I had a similar problem, turned out to be a DSO (dumb **** operator) error.
What happened was that I used the seat back control on the "centre of the car" side of the seat to move the seat forward, then I couldn't get it to go back properly.
Turns out that control is really just the seat back adjuster. Pull it up (push down?) and press the seat back back ito the correct position.
If that's not your problem, I can't help any more.
Good luck.
Old 08-17-2003 | 05:33 PM
Its311pete's Avatar
Its311pete
If resetting your seat doesn't work then you will probably need new handles or a new seat back frame.
I had a Mini in Fri. for a new seat back frame that wouldn't recline. Major pain to install a seat back frame, but fixed the problem.
Old 08-17-2003 | 07:26 PM
2minis's Avatar
2minis
I believe there was a recall notice('02) on this. You may
have to bring it in.
Old 08-21-2003 | 05:40 PM
DaveNagy's Avatar
DaveNagy
I had the opposite problem. After vacuuming under the passenger seat, it suddenly lost the ability to slide forward to allow back seat access. The seatback would flip forward, but the base did not slide unless you used the regular fore/aft adjuster handle.
I took it in, and it turned out that a cable had come loose under the seat. The tech snapped a little plastic doohicky back onto a bracket and, poof, fixed.
The fact that you were mucking around under the seat makes me wonder if you disengauged a similar, but different, cable.
-Dave
rtk90
08-29-2019 10:08 AM
gsredmini
10-20-2015 08:43 AM
newowner
09-15-2015 08:18 AM
SeattleF56
09-03-2015 04:01 PM
Ntety
09-02-2015 09:39 PM
