Supercharger/ water pump gear failure? What's the fastest it's happened?
Old 07-01-2011, 12:59 PM
Cadenza's Avatar
Cadenza
Cadenza is offline
Jim -
You can get this done for less than $2k, definitely even lower if you're handy with a wrench. When I bought my Mini and then learned about the S/C & coolant pump weakness, I got hold of a spare SC ($300) from ebay, sold by a local guy.
Good job with the repair and pix there, copi.
  #52
Old 09-28-2011, 04:30 PM
thevastdifference's Avatar
thevastdifference
thevastdifference is offline
I'm looking for a gates water pump too.. The seller on ebay has told me this is made of plastic. Is this genuine?? Does gates make plastic water pumps???
http://cgi.ebay.com/ebaymotors/GATES...item27bd8faef1
  #53
Old 12-25-2017, 04:57 PM
tonymtorres47@hotmail.com's Avatar
tonymtorres47@hotmail.com is offline
Originally Posted by SuperchargerTech
We now replace the 43 tooth & 24 tooth
water pump drive gears in the supercharger. We also
a gear replacement kit. We see this problem with the gears
on the MINI supercharger quite often. There seems to be
a problem with oil leaking out of the gear case. The sealant
used seems to be the problem.
We also offer a water pump gear/PTO gear replacement kit for $325.00
Kit comes with rebuilt rear plate (bearing,seal,43 tooth gear),
24 tooth gear, shaft seal,needle bearing,sealant,oil,magnetic
oil fill plug,etc.
Supercharger Technologies
352-542-0147 Fax: 352-542-9468
supercharger@excite.com
so question where the supercharger connect with the water pump The teeth on the supercharger broke is possible it can still run fine with one tooth on the super charger
  #54
Old 05-02-2018, 08:27 PM
drrigg's Avatar
drrigg
drrigg is offline
'04 R53 at 160k
I'm getting a chirping sound at startup that runs at engine speed and stops as soon as the engine temp hits 100 degrees. Is this the noise everyone is talking about that indicates a supercharger that's toast?
  #55
Old 01-05-2023, 03:47 PM
Geargirl520's Avatar
Geargirl520
Geargirl520 is offline
Is a rebuilt SC as reliable as a new one? I'm being told two different things on that front. That a rebuilt one will eventually crap out like the previous OR that a rebuild is better to associate with other older parts on the vehicle. That a rebuilt one wont put stress on the cam shaft, pistons, and head gasket.
  #56
Old 01-05-2023, 03:52 PM
Geargirl520
What did you end up doing? My shop is saying the same thing.. $4k to replace the SC, for parts and labor. But I'm being told that a rebuilt one is better for the car and that labor shouldnt be that expensive and is easier than they say... At this point I dont know what to believe, I just want to fix it. I'm told if you drive it with a bad SC it will blow the entire motor, so I'm scared to even drive it now. I just bought it two weeks ago..
TIA,
-M
  #57
Old 02-16-2023, 10:50 AM
Zsm's Avatar
Zsm
Zsm is offline
When my kid's R53 water pump failed it caused the seal between the supercharger and water pump to push coolant into the chamber where the PTO gears live. Granted the supercharger and likely water pump had 234K miles on it so anything could have failed at that mileage. I believe the supercharger is still good and it was just the water pump that went bad. (The water pump so bad, the bearings seized and caused the motor to stall) Given this car is not worth a whole lot, I didn't want to invest in a new supercharger so I went with a used one sourced from a junk yard I found through car-part.com.
I ended up spending $300 or so for a 2006 supercharger that was in excellent shape. Also installed a new water pump, flange, flange o-rings, coolant, new crank sensor o-ring (since it's right there), and a bunch of other parts since the front end was apart. If you're having a shop replace the supercharger and water pump, I'd imagine this is going to be a hefty labor charge.
That was back in 2018 so prices may have changed since then, but the car lives on at 246K miles and is still quite the hoot to flog around every now and then.
Zombat2142
09-17-2022 11:08 PM
Albiecrazy
04-07-2014 06:11 PM
kfmuller
Factory JCW Talk (2009+)
09-04-2012 08:16 PM
shadowwc50
06-16-2011 10:09 PM
gravedgr
06-04-2004 08:35 AM
Quick Reply: Supercharger/ water pump gear failure? What's the fastest it's happened?
