Some warranty work done on my new '08 MCS
As some of you know there is a heat problem in the driver footwell of the R56 after driving around for a bit.My MCS has the same problem and took it in to MINI for warranty work.I was told that it is a known problem and they are working on a remedy for it.My SA has an open RO on the matter and will contact me as soon as they know the fix for it.
Also had my Bi-Xenon headlights re-aligned because they were causing a lot of flashes from oncoming traffic and very angry truck drivers.
They were so out of alignment from the factory it wasn't even funny!! Problem fixed.
Plus had all 3 wiper blades replaced due to poor wiping performance.
And an oil change at 5050 miles that I decided to have done based on other members recommendation posted here on NAM.
The hot footwell issue has been around a long time. I personally don't have it, but some have it bad. It's a heater coil/hose that runs right next to the footwell on the driver's side that always has water in it. I think some have wrapped the part with insulation to lessen the problem. I never got why some have this and some don't, because I would think the part would be in the exact same place in every car. I can hardly feel heat there even with flip flops.
My SA did say MINI is aware of the situation also more in the European MINI Coopers and the engineers are working on a fix for it.
Thanks.
07-16-2020 12:54 PM
12-23-2015 10:36 AM
Drivetrain removing heat shields for turbo cat ?
rckrzy1
08-11-2015 06:06 PM
