Wheel bearing problem. Anyone else has this?
#51
This is exactly how I fixed the problem too.... Just to be sure when you're driving next time, try this... but BE CAREFUL
When the sound is very prominent at the specified speeds.. (65 mph to be sure) try veering in your lane a little to the left and right. If the sound goes away when you're driving in the direction that you hit the curb in at the time, then it's your bearings. I hit a curb turning left, for example, and when I'd turn left the sound seemed to disappear slightly.
#53
Hey, Toad, try this site, https://www.autohausaz.com/index.html
Just ordered front bearing for my 02 MCS yesterday, and shipped out right away and I will go pick up this afternoon. check the price, you will be surprised. lol
#54
I had noise coming from both front and back corner, I thought I need replace both front and rear bearing, but after i changed 4 new tires, the back noise gone, as it turn out, only front right bearing need replacement. So, guys you really need to be sure about what issue cause the noise. could be both tires and bearings.
#55
#56
on
I have an 05 R50 just turning 135k miles. I recently noticed/felt a grinding noise/sensation in the wheel and floor every once in a while, like a low vibration when coming to a stop and sometimes turning left or right. I think I'm going to replace the front bearings and see if that helps. It certinally can't hurt, after 135k miles I'm suprised they lasted this long...
#58
Think the Mini wheel bearing noise is a lubrication problem, especially on the rear bearings that don't have much load on them. If only you could get some heavy oil into them when they first get noisey, sure the noise would go away with some lubrication. Sounds like the bearings are running DRY, not worn out.
If only there was a way of getting some OIL into the bearing, like EP90 gear oil, just a drop to wet things up a bit, sure the noise would go away!
#59
The problem with most wheel bearings isn't from lubrication,It is caused by the ***** or the race getting small dents in them and the noise is created by the ***** running over them.Kind of like the expansion strips on a highway.I recently replaced a LF bearing on mine and knocked it apart to inspect it and found very tiny pits in the area of the race where the ***** run.The pitting was on the hub flange and as it is one piece it appears the race area wasn't hardened enough when the part was made.Plus I think 50k of use with run flats might have transferred a bit too much shock through the assembly.The only saving grace was it was easy to install if not exactly cheap.
#60
#61
Straight roller bearings in a wheel bearing application would destroy themselves pretty quickly due to misalignment caused by turning.It would concentrate load on one end of the roller.Wheel bearings used are double row angular contact type to allow for sideloads in combination with radial loads. Tapered roller bearings would probably last forever but they are more expensive to produce and maintain.
#62
Source for Bearings Only?
Has anyone found a source for the hub bearings by themselves? I ask because in the 35 years I've owned my VW Scirocco, I've changed hub bearings several times and it's dead easy. Providing you have a press and suitable tools to get the hub apart and back together properly. Seems like a waste to throw out an entire hub assembly just for the sake of a bearing.
Of course, I've only had my '04 S for two weeks so I'm still learning!!
Eric
Eric
#63
[FONT=Times New Roman][SIZE=3]wherf ..wherf… wherf or whhuuurrrrr...whhuuurrrr... whhuuurrrr, or whompf, whompf ..whompf or any thing close to a low growling type whirring noise especially over 45 mph where the noise is noticeable even with windows down or radio on is a likely sign that the bearings are like worn and due for replacing. I have had them go from 55k to 95k so it definitely is common and not just Coopers (Rendezvous & Chevy Blazers have a similar earlier than expected problem too). [/SIZE][/FONT]
[SIZE=3][FONT=Times New Roman] [/FONT][/SIZE]
[FONT='Times New Roman']I replaced one front hub and the difference was amazing!!!! [/FONT]
#64
#65
The bearing race on the hub side is integral with the hub.There is no separate race to remove.It appears that they machine the race portion from the chunk that is the hub then they must induction harden it and finish grind it to spec.Probably cheaper to produce that way.
Eric
#66
Bringing this thread back to life for a bit. My MINI starting hinting noises a couple thousand miles ago at a specific speed; at 30-37 mph at first. Makes a very faint vibrational rotating noise. The noise would also come and go depending on the temperature. Over time, it got worse. Now it's make noise all across the board at all speeds. At some speeds, it gets even louder. The noise is unbearable at all speeds. It is definitely a rotational noise because at low speeds it goes "worh...worh...worh" and at high speeds it goes "worhworhworhworhworh" I thought it was coming from the front passenger side so my friend replaced the wheel bearing on that side. But he says the sound is still there, and it sounds like it's still coming from the passenger side. I'm going to go and pick it up in 15 minutes and take a photo of the bearing that he pulled out. If I can't figure it out, I'm taking it to a dealer on Tuesday to have it looked at. I know for a fact it is not the tires, because I recently switched to my set of snow tires and the sound is still there. My questions is
-Could it be a CV joint or another problem in the front passenger side?
-Could it possibly be a bad wheel bearing on the front driver's side?
-What kind of problems can cause rotational vibration noise?
#67
Here's a video of the noise I just took.
http://www.youtube.com/watch?v=0pTa4...ayer_embedded#!
Photo of the bearing he took out:
I also notice as I was driving. While the car was cruising with the humming noise. The noise increased slightly as I veered left. The noise was either gone or very low when I veered right. Does this indicate which side the problem is? Or any indication what the problem may be?
#68
That certainly sounds like a wheel bearing. Can you get it on a lift or jack it up and run it? With the wheels off the ground you should be able to discern which side it is by using a screwdriver at your ear[pointy side down] and placing it on the top of the strut and running it in 3rd gear at idle. As far gone as they sound you could probably just feel it with your hand on the strut. Bearing noise from the rears can also sound like it's coming from the front too.The same diagnosis proceedure applies but you need to spin the wheel by hand and it is best to have the screwdriver on the area behind the wheelbearing.
#69
#70
#73
Because I had never heard of anyone having this problem....and since I thought it was tire noise for a long time......I went a long while without having the problem fixed. And as you mentioned, it gets worse fast......BUT...I don't think you'll ever get play in the wheel. Even after being shot for a good few months, there was zero sign of play in the wheel....and the regular test of shaking the wheel to notice play showed no signs of bearing issues despite obviously being a bearing problem.
Just a heads up for those who are used to checking for bearing issues by looking at the play in the wheels.
#74
My car is making a noise when i turn my steering wheel counterclockwise. I can hear some kind of metal noise coming out from the front passenger wheel.
I stop and shake the tire and it feels loose. does this is a sign of a bad wheel hub or not?
I will check tomorrow the tire see if the bolts have the right torque.
#75
