Running the car on dead battery
Hi all,
Question.. would running the car on a dead battery after jump starting damage the alternator in any way? Someone told me that since the alternator is trying to recharge a battery that is not accepting any charge, it would damage the alternator...
Please let me know if this is wrong....
Cheers...
Ron
Cheers...
Ron
theres not too many people that will chime in here, mostly because its possible either way. I WOULD GUESS that it can hurt the alternators diodes and not be able to rectify your voltage. you may also damage the diode bridge from the alternator not baing able to determine how much charging voltage is needed.
again this is all a guess-i never went to Alternator Academy
You are just asking your alternator to not just replace battery wattage, you are asking the alternator to run everything all at once, just a large load on the alternator. Short time, no problem, long time, not advisable.
When in this situation and trying to get home or to a shop, just turn off every electrical load you can.
YD
YD
on
YD
YD
Drivetrain removing heat shields for turbo cat ?
rckrzy1
08-11-2015 06:06 PM
