Can Car Wash Rails Change Camber
Some of you may have seen my post about suspension issues. I went to an automatic car wash today, and when I drove out of the tunnel I noticed my Minis rear suspension (drivers side) didn't have that uneven feel that it has had for weeks.
I checked the rear and it seems that the wheel has less negative camber. could the springs be the issue or the camber plates, because I like the way the car drives now. It feels level on the highway.
I can't imagine that the car wash would have anything to do with your improved alignment, unless there was a one-in-a-million shot where your car got jammed up for a bit and the conveyor yanked it with just the right amount of force in just the right spot to improve your ride. Not likely. Why not just take it in for an alignment check to see if everything's in spec?
I had an alignment done a week ago and it didn't solve the issue. I'm thinking the spring or shock is not installed or positioned correctly.
The dealer said they couldn't find anything but we all know how reliable they are. I have an appointment on wednesday and i'm having them take the spring out and remove the shock and inspect...of course they are charging me!
Alignment has nothing to do with the car being level (you said it's level now, wasn't before the carwash). Unless it's way out of alignment you probably wouldn't notice anything different until your tires started to wear unevenly. If the rear seems unlevel it's a suspension issue, something not screwed down tight enough. An inspection should show the problem, not an alignment check. A loose suspension part isn't good to drive on either. Not safe if it's a loose spring or coilover or subframe, etc.
1chaos52
08-24-2015 01:28 PM
Minibeagle
08-13-2015 10:00 AM
ClayTaylorNC
08-10-2015 09:19 PM
