Flywheel recall
on
Flywheel recall
My tranny was making weird noises so I took it to AAMCO in Leesburg, VA and they said it was probably my flywheel and that MINI had recalled the flywheel in MINIs up to 04 because it wasn't strong enough. Has anybody had this problem? And were the noises gone after the flywheel and clutch were replaced?
on
I am so glad they fixed it because the noise was driving me nuts. Yes after they replaced the flywheel the noise went away. The car drives great and actually always has, it just had that noise like a helicopter hovering.
Good luck, I hope your car is under warranty because he told me that if I had to pay to get it fixed it would be about $2,400
Had mine replaced about three months ago. Sounded like a helicopter noise coming from the tranny. The dealer replaced it under warranty. There is a service bulletin out there that states they only have to replace it if the customer complains about the noise. Supposably it will not harm the car, but it's annoying as heck. One mine was replaced, the noise was goine.
Had a noise like a throw-out bearing was going on my 06 MCS . Took it in for the 30,000 mile check, told them about it. They diagnosed a flywheel problem. Gave us an 07 MCS with the paddle wheel shift to use. What fun. They replaced my flywheel and clutch at Northwest Mini under warranty. The noise is gone now. Chili Pirate
on
Thats odd....didnt know the flywheel had anything to do with the clutch being depressed other than engauging the disc when applied. I think all your dealers b/s you because the noise you mostly are hearing is the throw out bearing which will make noise with the clutch pedal out and quiet when its pressed.
they replaced the flywheel because the springs on the dual mass were weak and on certain cars clunked when letting the clutch out in gear. im sure on all the above concerns they replaced the clutch also.
the flywheel was a TSB. Not a recall
at idle and with the clutch in neutral, my car sounds like someones beating on my block but i have a lightened flywheel and lightened crank pulley so that sound is normal as there is no damping to muffle the drivetrain
Pedro99
10-03-2015 10:56 AM
09-28-2015 09:13 AM
