car will not start , clutch related problem !
on
i have a problem where the car will not start because i can not press the clutch down far enough to get rid of the cars safty feature.
it has been doing this more and more in the last fiew weeks. i would guess it is some sort of switch that gets turned off when the clutch is pressed all the way down than the car will start.
can some one tell me what to look for ?
thanx
thanx
The switch is a hall sensor located on the side of the clutch master cylinder. It sends a "neutral" signal to the EWS and EWS module allows it too start.
Several conditions must be met in order for EWS to engergize starter relay
EWS must like the key in the switch
Start signal from Ignition switch
Neutral from clutch switch
on
Colt45Magnus
08-12-2015 06:43 AM
quality_sound
08-07-2015 09:36 AM
