Measuring Water temp?
My car should be ready for pickup today after 26 days at the dealer for multiple overheats. The most recent overheats were traced to a head that was slightly warped. Problem is, MINI won't authorize the dealer to reinstall my driving lights...they still think the lights could be causing the issue. If I choose to put them on and another overheat occurs, there's a chance I'm buying the next overheat (unless a failed part is clearly identified. So unless another incident occurs with my lights uninstalled , I can't put my lights back on unless I'm prepared to accept that risk or fight them in court.
What is the easiest (economy being a factor as well) way to measure the water temperature? I'm thinking drive around without the lights, get the car warm, and measure the temps. Then, bolt on the lights and repeat, looking to see if the water temp increases. Thinking Scan Gauge II but that ain't cheap.
Found this in one of the forums, don't remember where - coolant temp is item 7.0 following the instructions. Proceed at your own risk:
The information displays in place of your odometer, so you DO NOT have to have the MINI OBC/Trip Computer option to see this.
A complete list of functions is below, this example is how to get into the menu number '7'.
1.0 Chassis number
1.1 Kilometer count
1.2 Parts number
1.3 Coding-, Diagnostic- and Bus-index
1.4 Production Date (Calender week/year)
1.5 Hard- and Software status
1.6 Injectorstatus, Cylinder count, Engine factor.
2.0 Combisystem Test
3.0 Service intervall counter
4.0 Actual fuel consumption in l/100km. eg.0154 = 15,4 liters/100kms.
4.1 Consumption in liters/100kms.
5.0 Distance consumption in l/100kms.
5.1 Actual rest distance with available fuel in Kms.
6.0 Actual amount of fuel in tank. eg. 123321 =12,3liters left 32,1 liters right
6.1 Total amount of fuel in tank.
6.2 Show value of Fuel guage. 1= both senders OK, 2= sender failure, 3=ti signal unplausible (no reading)
7.0 Actual coolant temp.
7.1 Actual outside temp.
7.2 Actual engine revs.
7.3 Actual speed
8.0 Hexadecimal readings of menu 7.0 to 7.3
9.0 Actual on board voltage (Battery)
10.0 Land codes
11.0 Unit codes
12.0 No funktion
13.0 Gong test
14.0 - 14.4 On board diagnostic codes. eg 000000 = no failures
15.0 - 18.0 No funktion
19.0 On/Off for Test menu.
20.0 Correction factor for Fuel consumption
Formula for correction:
Shown consumption x 1000 / user defined consumption
Push the trip reset button to begin the correction. Numbers count up from 0-9, when correct number shows push trip reset button.
20.1 Sets 10ths. for consumption factor
20.2 Sets 100ths. and 1000ths. for consumption factor
20.3 Saves the new consumption factor and shows new value
21.0 Software reset. (Same as disconnecting battery)
- With the key in the ignition, but in the off position, press and hold down the odometer reset button, while holding the button down, switch the key in the ignition to position 1.
- The screen will say 'Test' and a number.
- Scroll through, (pressing reset button) through to test 19 and wait a moment.
- Wait and the message will say "log i-off" then "log i-on" and back to "log i-off" again. When "log i-off" appears, press again. You are now in the system.
- You can (if you wish) start the ignition any time from now.
- Scroll through to test 7.0 (or whichever from the list below) and wait a moment, after a pause you will enter the test 7.* range of information.
- You can scroll through now (7.1,7.2,7.3 etc.) using the reset button.
- You can exit each menu by pressing, holding for a few seconds, then releasing the reset button.
- To leave the system scroll to 19 and leave it for a few moments.
Switching off the ignition also exits the system.
1.0 Chassis number
1.1 Kilometer count
1.2 Parts number
7.3 Actual speed
10.0 Land codes
11.0 Unit codes
12.0 No funktion
13.0 Gong test
I'd just get the ScanGauge. I have one hooked up and am monitoring water temp among other things. Very simple to hook up and use.
With that hooked up I'd drive a week without the lights installed and see how it goes. Then hook up the lights and see if there is a change. I have two lights down where yours are and have never seen a change in temps.
I agree with the ScanGauge II. You can monitor both the water temp and the intake temp to see what is going on. It is much more accurate than the stock gauge. This should also allow you to keep from more overheats.
You are correct it is not a real low cost option but I think Wayland had them for about $150. Also you can move it to other cars if not needed in the MINI.
Probably a dumb question, but is Scanguage II easy to install in the Mini? I mean, for a true neophyte? I hate buying stuff that says "easy to install..." or "quick and easy..." and then it turns out not to be the case. I'm interested in getting one, as altho I've loved every one of my 18,000 (trouble-free, knock on wood!) miles, I'm still not used to not having some ready reference for coolant temp.
Do a Search Titles Only for "scangauge" and you'll find threads with pictures of mounting locations.
With the optional programing in the SGII you are set for many of any ECU reading.
elverado
01-18-2022 02:51 AM
patsum
26
05-29-2021 06:29 PM
Rohdeandschwarz
11-05-2015 07:58 AM
