Brake light issue??
Brake light issue??
You'd think it was a pretty open and shut case right? Its on a 04 S with the 5th brake light mod.
Passenger side brake light will not light, the middle light will still turn on.
Replaced the bulbs, nothing happened.
Double checked the bulbs. nothing.
Removed 5th brake light wires. nothing
Switched the Panels that hold the bulbs from right to left. guess what. nothing
Is the passenger side light fused or something? anyone ever seen this?
the culprit:
the culprit:
![](http://i47.photobucket.com/albums/f164/96glxbot/NagsMINI.jpg)
Ahhhhhh.... I was confused - you're doing the "jumper" between the brake and fog on your pre-facelift taillights...
Possibilities... broken wire... pushed the wire out of the connector inadvertently... or (horrific worst case) Body Control Module failure....
I doubt the door lock is related... though if your BCM is going out, I guess that's possible....
I'd get a circuit tester (little needle thingy you push into the wire to make contact, with a light and a ground wire/clip) and test the brake wire further up the harness with the pedal depressed - is it getting power? Which would mean problem is at or near the connector. If no power, either you have a break further up the harness, or may have a BCM failure.
Well, the official name for this is "brake light mod", which involves "bridging" the brake light and unused -but intact- fog light using a piece of wire as Blimey mentioned above...
It has been a good discussion whether this is safe or not, since it adds extra 40W to the BC1 module. Some experienced BC1 failures due to this, and some had it since early 2002 with no problems.
Since you already eliminated the blown bulb option, it "might" be the BC1 module. I hope not, because that is an expensive piece.
Search for "brake light mod" and you'll have number of threads to read...
Good luck!
Good luck!
07-16-2020 12:54 PM
Etrain
14
08-20-2015 10:32 AM
