Door trim lifting off
Wondering if anyone else is having problems with the silver door sill trim lifting off. I've got an '08 Clubman S and it is happening on both passenger and drivers side. The passenger side lift was enough that the door caught it the other day and totally mangled it. I checked the drivers side and the same thing is starting to happen there. Here are some pictures.
Unfortunately, I'm about 5 hours (one way) from the dealership. They say the won't replace it unless I bring it in. I don't want to spend 10 hours driving and $80 in gas to replace a $57 part. Trying to get them to at least sell me the part at a discount but they are telling me "there is nothing they can do".
The exact same thing happened to me a few weeks ago. Your picture looks just like my passenger side. I plan on taking it to the dealer sometime (I live 2 hrs. away), however I did find a decent fix to get me by. I first tried to flatten the strip as best as I could, using my fingers and pliers (use cloth on the teeth to prevent marring). I then put down a strip of double-sided tape my wife had bought from a craft store & pressed the trim down on the tape using a small wooden roller (from my wife's cooking utensil drawer). So far so good. Note, I did not totally remove the piece but rather gently bent up the loose section to apply the tape. As long as you do not kink the metal, it should press back down. And, for the record, she does NOT know I used her pie roller thingy on my car.
We had the same problem. Passenger side metal plate sill was lifting up from the front edge towards the back. By the time we noticed the problem, the sill was mangled and totally smashed.
Took it back to the dealer on Sat morning and to my surprise, they had both driver's and passenger side Clubman S door sill replacements in stock. Done under warranty and both replaced (Driver's side was heading the same way as the pass side sill). It took 2 hours to get the old sills removed, glue residue removed, prep area, add new glue, install new sills.
They look better than the ones put at the factory. I left the blue film plastic protectors in them.
This was a minor but very disappointing cosmetic problem on a nearly $30K premium automobile. Out of the 4 MINIs we have owned in the past 7 years, this has been the only one that has had both door sills come off unglued and replaced. Another sign that MINI has gone cheap with the build quality of the second generation MINIs.
These sills have updated part numbers and therefore they are supposed to have stronger glue bond and more resistant to water and dirt. I'll be happy to post the part numbers for both driver and pass side door sills on the Clubman S model for future reference.
M7Speed
09-04-2015 10:47 AM
