code p0130 in 04 MCS
Hi everyone,
My 04 MCS (with 145,000km on it and it's a stock except for the Volt exhaust) has just throw me a P0130 code this morning according to the Scangauge II. Understand that it's the O2 sensor Bank 1 Sensor 1 malfunction. Since it's Sunday today and I have many errands to run, do you think it's ok to drive it as usual for the day. I'm probably going to put at least 300km until I can get it fixed on Monday.
By the way, I was trying to clear the code from the Scangauge II, the code had been cleared but the SEL stayed on then it threw the same code again right away. My question is that will the SEL light go off itself once I have the malfunctioned O2 sensor replaced or I have to reset it in the dealer?
Thanks for your time ...
Cheers
Stephen
Cheers
Stephen
oxygen sensor
They are rather pricey, I bought mine from Advance Auto Part/Parts America for about $150.00 each. May be good to shop more but be sure to get Bosch. If yours are the originals, I'd replace both as Mini recommendations is the replace @ 100K (for non-s). Also, it is ok to drive current state, just may not have optimal fuel mixture/emissions control till corrected.
Check the wire going to the sensor, make sure its not touching the exhaust plumbing. here is more info...
http://www.obd-codes.com/p0130
P0130 When Wet
So,
I have been getting a P0130 only when wet,
I washed the car, and under hood, Lamp came once
Cleared code Car ran perfect.
Then a wet slushy snow that melted off in a few hours happened, and check engine lamp came on,
Now its dry , no more code, i have checked the connector and it looks dry and all rubber seals are in place,
Any one had this issue?
alistaircookie
10-08-2015 10:52 AM
