Pulsating Hum at 3k to 3.2k rpm
Just took a 12 hour interstate drive and noticed that around 3000 to maybe 3300 rpm there was a slowly pulsating deep hum. The kind of sound a rotating body makes.
If any of you are familiar with twin-engine prop airplanes, it is the kind of pulsating sound you get when the props aren't synched with each other. Kind of a waaaaa-waaaaa-waaaa.
Increases with rpm. Goes away when put in neutral, so I don't think it's tires.
May be present at other rpms, but most noticable at the rpm range indicated.
Ideas?
Ideas?
First, what year is your vehicle, and what model?
When I first picked up my '07 MCS 6-speed (turbo version, by the way) in Germany, there was an odd rhythmic thrumming to it when I hit 55mph or higher that did NOT happen in my '04 MCS 6-speed. I could feel it through the floor and stickshift! I was getting ready to leave Germany, so the BMW mechanics (although they could feel it) couldn't fix it before I left (They were BMW, not MINI specific.) The German mechanics suspected it was the thrum of the turbo. When I had it checked out here in VA after shipping, nobody believed me on the thruming. I've had tires checked, engine checked, etc. You name it, I had it checked. Nothing.
So.........? I'll be interested to hear other folks' theories on your situation, too! That way I won't feel so crazy...
ditto
Had a local tire mechanic diagnose a wheel bearing upon first hearing the noise. Twenty min later, determined it was right front. Dealer initially said there was no issue after trying their own set of wheels/tires, but after several more hours determined it was the right front wheel bearing. They replaced it under the warranty. Noise is gone.
Thanks for responses. I will be doing some in-depth observations over the next couple of days and will send them off to the dealer (2 hrs away) for an initial contact/opinion.
Of course, they'll tell me to bring it in and then will likely say it's normal, but I don't think so.
What I've noticed is that it varies with speed, but goes away (or becomes inaudible to my old Army ears) around 3400rpm. I can convince myself that I feel it, but am not ready to claim that isn't the power of suggestion, yet.
Will keep you posted (...Oops. I'm supposed to say y'all, now that I live in Alabama.) Hope y'all do the same with your thrummmmms. (I do like that description.)
r
r
Our '07 mcs took us to Mo. & on the way back I thought I heard a rotational noise as well but wasn't sure why. Certain curves quiet it while the opposite curve amplifies it. It changes with speed & sometimes is hard to hear. I'll go along with the wheel bearing being the culprit & it's going to the dealer next tuesday. I'll post the results when they fix it.
Tire noise
After taking a tech for a short ride so he could hear the noise, they put on a new set of wheels & tires. Took the same route w/the same tech,but no noise was heard ! He also noticed a lot of wear on one tire as I did during the last tire rotation. He put all 4 of mine on the Hunter GSP road force measurement machine while I watched. They were all out of balance,even tho I felt nothing thru the steering wheel. It rides smoother but the noise is still there & very annoying since it's louder at 55 & up to 70 where it becomes less audible (different pitch ?) These are Kumho 205/50x16 ecsta asx w/a 30k+ mileage warrantee. They were quiet when new,until just under 29k miles.Needless to say I'll not be buyin' kumho tires again. Any comments about better tires will be appreciated.
elverado
01-18-2022 02:51 AM
Miniwaukee
09-29-2015 09:22 AM
