WARNING:: OEM Plate frame causing RUST
For 3 years I've had the OEM "Lets Motor" black plate frame installed on my hatch. Today, I was detailing and did the quarterly plate removal to clean underneath the plate and noticed something disturbing.
The top of my plate frame had been cutting into my paint, it just the clear coat paint and primer down and the metal has started to rust. the gouge to the primer is just shy of the width of the VIN placard below it, the rust is spotted throughout the center.
I have to go to the auto parts store to get some paint repair supplies as I am well out of warranty, so I will post the photos of the damage later tonight, however I wanted to get the information out there ASAP so other people with metal OEM plate frames can check to make sure they do not have similar damage. If you do please post here and post photos of the damage if possible, I'd like to see if this is a one time or common trend, if it is common I want to notify MINI so more cars (esp those of non enthusiasts that don't read sites like NAM) wont have to suffer the damage.
The stock one is NOT going back on, I will be installing an aftermarket one that will be lined with weather stripping. Based on where the padding was on the OEM bracket, as long as I clay bar and wax before install the new bracket will be flush across the paint instead of tiny patches, eliminating the chance for anything but foam to touch the paint and minimizing vibration. Also the new brackets lack over hang and are all plastic instead of metal. Preventing further rust is the primary goal.
on
putting paint over rust isnt going to help but just mask the problem until it gets worse. you will need to sand the area down and get ride of the rust and prime and paint.
being i know that isnt a option for most of us to do and the area your doing is sorta hiden mostly. goto the part store and find something called navel jelly. its a product that stops rust and reverses the process from spreading. then you can just touch up the area with a paint stick. good luck
blackie
10-02-2015 07:41 PM
AdrenaliNate
08-24-2015 12:37 PM
