New pads + rotors = thunking?
So I changed my worn out (front) stock pads to HPS pads a few weeks ago, and all was well. I finally got a chance to change the rotors today, and to make a long story short, I had to snap the heads off the torx bolts that retain the rotors in order to remove the rotors. I was concerned about operating the car without the bolt in place due to excess slack in the rotor assembly as a result of a loose tolerance between the lug bolts and the rotor, but the general consensus I got from the few people who answered my post was that it is OK to drive without the retention bolt. (see https://www.northamericanmotoring.co...d.php?t=157349 for more detail)
I couldn't find any conflicting information elsewhere, so I took the car out to bed the pads. About 10 stops into the process, a soft, rhythmic thunking from the driver's side wheel area became apparent during moderate braking. There is no pulsation in the pedal, and the car stops smoothly. Everything is in place and tight, and the rotors show no signs of movement (I marked them) despite not having the retention bolt in. I can't detect anything abnormal or out of place, and yet the thunking won't go away.
Useful info:
2005 MCS, 40k miles.
Pads: Hawk HPS, with roughly 200 miles on them
Rotors: Brembo OE-style replacement rotors
Useful info:
I checked again this morning in better light - everything is tight and in place as it should be. A quick trip down the road revealed the same thunking.
My local MINI service dept. suggested that it could be the heat shield banging against the rotor after having been tweaked during rotor installation... To me, the sound is a bit dull to be a heat-shield related noise, but the SA says he gets the complaint a lot that's what it is 99% of the time.
I've got aftermarket rotors and pads: TSW rotors and Bobcat pads I purchased from AutoXCooper.com.
I still get a thunking sound that goes away when I apply the brakes even slightly. Numerous times I've had the rear calipers off to inspect the inboard pad... they had popped off the piston head and I had to snap them back on. This past weekend they still appeared to be in place. It's defintiely the rear set as when I apply the parking brake while driving the sound vanishes.
One thing I notice is that with the pads/dogbone removed, the rotor spins freely. With everything together the rotor does not spin freely. Pretty restricted.
Do the rear caliper pistons need to be manually rotated in with the (Harbor Freight) piston compression tool? I would think they would retract off the rotor surface by the natural braking action. Learning...
The sound isn't much like I would imagine it would be if the heat shield is somehow in play - it's a very dull "thunk", similar to hitting your palm against a desk or something like that... Based on the sound alone, I would sooner suspect the control arm bushing or something like that. But why would that suddenly spring up after a brake change? And would it really go out at only 40k miles on completely stock suspension?
Did you clean the surface of the rotor that sits against the hub? Did you clean the mating surface of the hub also? It doesn't take much crud or rust on this surface to prevent the rotor from sitting perfectly flat against the hub. It would be easy to have a little burr left over from when you had extract that torx bolt, that could cause things to not sit flat also...
You want these surfaces to be good-n-clean but also free from any oil or grease.
Jason
Jason
From my experience, no pedal pulsation. My guess is the floating caliper just follows the rotor, but the thickness of the rotor does not change therefore not forcing any fluid back to feel in the pedal.
Just my experience.
Jason
I was bemoaning my switch to slotted rotors and after a few weeks was ready to take the assembly apart and try applying more caliper grease when I began to notice that the noise wasn't there anymore. I've motored for 4+ months since and have not heard a single knock. I inspected the pad assembly and it is still properly aligned, not wedged or caught abnormally.
I ended up concluding that there must have been something along the rotor surface (pad material?) that was causing uneven friction, maybe a result of inadequate bedding. Once I worked my way past it, the brakes have functioned perfectly and quietly.
Just a possibility; remember floating caliper brakes like ours work by having the pads oh-so-slightly in contact with the rotor but not really snug against until pedal pressure is applied; it's amazing how tiny noises get amplified and telegraphed through mechanical bits of a car.
Good luck hunting
I get the 'pad material stuck on the rotor' problem every time I go to the track. It usually takes 25-50 miles of normal street driving to shave everything off and get the 'click, click, click' pedal feel to go back to a norma, smooth feel.
Congrats on a solid diagnosis. Good luck on the fix.
unxpectederror
10-22-2015 01:16 PM
