helicoil tang removal help
Just installed a helicoil in my blown spark plug hole and all seems to be fit and snug. Just cannot get the tang removed. I've been everywhere looking for a long set of needle nose pliers but no dice on finding them as long as I need. Any advise recommendations would be greatly appreciated. Thanks in advance
got it. chaulk it up to luck or what have you but I used some thin metal 'rope' I had around the house and looped the tang. Then used some greese to put a small coat in the plug hole.. pulled up on the metal rope and it snapped right up and stuck to the greese in the hole. then used a long magnet I had to grab and toss it out. Phew.. what a fun time. false alarm I guess but thanks so much 'daflake' for your quick response. I did try the backtap method but the hole seemed to be too stripped, The helicoil worked great and hopefully the end result is good as well. thanks again!!
UncDeo
11-04-2019 04:08 AM
09-02-2015 09:05 AM
Interior/Exterior Another hood stripe removal thread
broncobuddha
09-01-2015 06:32 PM
