2nd gear issues :(
2nd gear issues :(
Well this all started after installing a 15% pulley. As most of you know you have to raise the engine up quite a bit to do this. Could doing this have caused my linkage to bind up?
I ask this because I can not quik shift into second gear during a WOT run. If I baby the car and shift at 2500-3000rpm I can shift into second with no issues. But if I attemp to shift at anything over 6000rpm I can not even man handle the shifter into second.
Because this began after the pulley swap I assume I have bound linkage brought on by the engine shifting forward during hard driving. I will be adding all Powerflex bushings to the car next Monday.
Would it be safe to assume that rasing the engine up could of pulled the linkage tight? Also are there any clips that hold the linkage under the body of the car? If so then maybe I could take them loose and that will alow the linkage to move back into OEM specs them place the clips back on.
You could start by taking your airbox out and inspecting the shift cables under that. When I did my 15% pulley, I was told that there is enough slack in everything that the engine could be raised without any issues.
Just thought I'd ask this: do you guide the shifer with an open hand, or do you shift like you're mixing concrete?
Well I just went out for dinner and was very carefull about how I shifted into second and everything was fine. Rather than getting excited about the fast approaching redline I concintrated on gently pulling the shiter back into second by cuping my hand around the front of the shift **** and easing it back rather than a fist full of shifter and yanking it back.
Well I just went out for dinner and was very careful about how I shifted into second and everything was fine. Rather than getting excited about the fast approaching redline I concentrated on gently pulling the shifter back into second by cupping my hand around the front of the shift **** and easing it back rather than a fist full of shifter and yanking it back.
09R56
11-16-2022 10:49 AM
tacticalbacon02
08-22-2015 06:05 PM
Colt45Magnus
08-12-2015 06:43 AM
