Electrical issue or just cold weather?
(It was 22 degrees when I went out to check the car today)
Last night I noticed that my driver's side window did not drop when I opened and closed the door. However, my passenger side window did drop during opening and closing.
This morning I checked again and had the same results, except now I noticed that when I unlocked and locked the car from the key fob, the exterior lights did not flash. So, I locked and unlocked the car again and again and sometimes the lights would flash and other times they wouldn't.
Could cold weather have anything to do with this problem? I've had the car since 2006 and haven't had an issue like this except for the door window not dropping because it was frozen.
I've searched the forum and found that I may have a bad window motor, but my window works fine going up and down, except for when I open and close the door. I also held the window switch in the up position for a couple seconds to try to reset it, but I'm not sure if that really works or not.
Cold weather window issues.
[QUOTE=MBR;2562634Last night I noticed that my driver's side window did not drop when I opened and closed the door. However, my passenger side window did drop during opening and closing.
I've searched the forum and found that I may have a bad window motor, but my window works fine going up and down, except for when I open and close the door.[/QUOTE]
I've been having the exact same problem lately, very annoying, especially when trying to exit the car, as the window never drops and it is very difficult to close the door without damaging it! Did anyone ever figure out why this is happening? It definitely only occurs to me when its at or below freezing outside, and I had the same problem last winter but it seems like it could be getting worse. I also noticed that my interior courtesy lights were not turning on when I had my driver's door open this morning, could these two be related? Perhaps the dome light and the window drop when the door is opened are on the same sensor?
I'd love to find out its some easy and cheap to fix issue, but I have a nagging suspicion that this is going to be an expensive gremlin...
Have you guys had any luck with this issue? I can't get the 'holding the window switch up/down for 2-3 seconds' trick to work. Also, I've taken my car in to have the battery checked and it seems to be working fine. Never had any problems starting either. Problem only seems to happen in the extreme cold but it doesn't seem to be caused by ice freezing up on the seal as it happens whether or not there is any moisture there.
-Brian
-Brian
07-16-2020 12:54 PM
minicoclub
11-11-2015 07:25 AM
